Cap Off Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 02:29 PM   #1
Cap off radiator
I have a radiator in the middle room of my house which heats up more
than the radiators in the front & back room?
I tried turning the valve both ways but it doesn't seem to affect anything?
Would replacing the shut off valve solve to problem or capping it?
Thanks in advanced!
Carloscda40 is offline   Reply With Quote
Old 01-22-2009, 06:27 PM   #2
Custom Cabinet Maker
I would say you just cant cap it cause you have a hot water loop and by removing and capping you will most likely really mess up the rest of the system. You MAY be able to pull the top of that valve off and replace the washer inside. IT WILL NOT BE EASY, THAT HAS BEEN THERE A LONG TIME and it LIKEs it there.
Much as you dont want to in this case I think you really need a plumber, depending how the system is run, you may be able to get under it and re plumb it to bypass it, but you cannot just do that without really knowing how the system was done.
skymaster is offline   Reply With Quote
Old 01-22-2009, 06:51 PM   #3
Learning by Doing
Leah Frances's Avatar
Go to: www.heatinghelp.com and start reading. Post on the 'Wall' they are experts on radiator systems and can help you.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
No/little heat on 3rd floor apt collar Plumbing 3 12-06-2008 08:17 AM
Radiator Question mismos00 HVAC 17 11-02-2008 03:55 PM
HELP! poor daugthers radiator question fauer Automotive Repairs 6 03-16-2008 05:25 AM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 08:09 AM
downsizing radiator aak3 Plumbing 1 02-14-2008 05:14 PM
