Can't Locate Fuse On Heat Pump Circuit Board - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 06:23 PM   #1
Can't locate fuse on heat pump circuit board
My home' s air stopped working. Checked heat- does not work not even fan. Fairly new home (less than 10 years old) Thermostat seems to be fine, can hear click sound when turning ON heat or air. Been trying to locate the fuse in heat pump's box to no luck. It has Honeywell circuit board. Could I get help in finding the fuse location? I snapped couple of pictures of the board.
Can't locate fuse on heat pump circuit board-ciircuit-board.jpg   Can't locate fuse on heat pump circuit board-ciircuit-board1.jpg
Ron2000 is offline   Reply With Quote
Old 10-03-2012, 06:46 PM   #2
Houston204's Avatar
Rewards Points: 556
Probably doesn't have a fuse.
If it did, it would be in line with the fan relays.
Check the back of the circuit board for damage.
Houston204 is offline   Reply With Quote
Old 10-03-2012, 06:47 PM   #3
Rewards Points: 616
why are you looking for a fuse...do you have line voltage.....
carmon is offline   Reply With Quote
Old 10-03-2012, 07:24 PM   #4
Rewards Points: 558
I’m no electrician but shouldn’t you check the main fuse box to see if a breaker is tripped?
epson is offline   Reply With Quote
Old 10-03-2012, 07:35 PM   #5
Thanks for the quick response. Breakers are fine. Heat pump and outside air unit's capacitors are also checking good. Seems to be just blown fuse or is it possible they have this board without fuse. In that case any electric surge or short circuit could blow the board. Also outside unit is
getting power, I was able to run the fan with direct contacts.
How do I check if circuit board is good?
Old 10-03-2012, 07:36 PM   #6
Yes I have line voltage.
Old 10-03-2012, 07:41 PM   #7
You think circuit board is bad? Do I pull out the board, and what
damage I am checking. Visual or with multimeter? I am mechanical
engineer but know little bit about electrical and HVAC
Old 10-03-2012, 07:56 PM   #8
Rewards Points: 582
the clicking sound you hear....is it in thermostat,,,,if so confirm 24 volts on control board...and transformer...
Old 10-03-2012, 08:12 PM   #9
An old Tradesmen
Rewards Points: 7,370
Yep, see if your transformer is putting out 24 volts.
Old 10-03-2012, 08:14 PM   #10
Houston204's Avatar
Rewards Points: 556
If it is the stat clicking check for 24VAC between R and C.
Old 10-04-2012, 12:39 PM   #11
Rewards Points: 156
can any of the low-voltage wire connections on his circuit board be jumpered and have the unit start for testing purposes? Whichever one it is, if the unit starts, the problem will then be between the control board, and the stat inside the house. If not, then it's this circuit board, pending it's got power
av-geek is offline   Reply With Quote
Old 10-04-2012, 04:03 PM   #12
Houston204's Avatar
Rewards Points: 556
R = 24 volt power
G = fan
W = heat strip
Y = compressor
C = 24 vac common
Jump R to G to run the fan.
Avoid jumping R to C since this would be a short and would damage the transformer.
The Following User Says Thank You to Houston204 For This Useful Post:
ben's plumbing (10-04-2012)
Old 10-04-2012, 06:35 PM   #13
R = 24 volt power
G = fan
W = heat strip
Y = compressor
C = 24 vac common
Thanks all. I'll try tomorrow. Good thing it's in seventies here and I don't need heat/ air for few days and I can keep testing.
Old 10-05-2012, 01:58 PM   #14
Cool! I am an electrical engineer! Similar thing happened to me a month or so a go with my ignition board. Visual inspection can tell you a lot. On mine a trace on the board had burned through. I repaired the trace, and it's back running fine. See link below for photo of what the burnt trace looked like (in this case).
Blower motor in AC unit not coming on
Big John Studd is offline   Reply With Quote
Old 10-09-2012, 04:49 PM   #15
Yes that is it! I should have checked first thing, 0 output from the sec. Also little burning smell. Ordered new transformer on line. My only concern is if something else could be wrong on the circuit board. What if I install new transformer and it also fries. Thanks guys! great forum!
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 08:41 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 09:47 AM
