#1 |
Cant install HRV?
All,
I have had 2 separate HVAC contractors come to my house to pre-inspect for installing an HRV. Both said that it wasn't doable due to the 'grade' or how close to grade my basement was (or windows). I must not be the only home with a low basement, which leads me to believe there must also be a solution for to my home not meeting the standard requirements. Has anyone had a similar situation? |
#2 |
An old Tradesmen
Cant install HRV?
Sometimes you can go up through a pantry or linen closet to the attic on single story homes.
#3 |
Hvac Pro
Cant install HRV?
it may be possible if they go thru the wall then dig into the ground and then gooseneck the pipes up above grade and the average snow fall level. if not high enough it will suck in snow and feeezeup. not a pretty looking setup but it is possible with extra work and cost. google Lifebreath HRV and check their site as you may be able to look at their install info
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by yuri; 08-20-2011 at 09:37 AM. |
| Display Modes | |
| cutting shingles to install gutters | Chicago Bill | General Discussion | 2 | 02-27-2009 06:42 AM |
| New Cased Coil - Install to Furnace - PICTURES!! | hartkem | HVAC | 39 | 11-18-2008 02:45 AM |
| When to install tile flooring? | MT Stringer | Remodeling | 4 | 10-28-2008 09:49 PM |
| How to install resilient channel on ceiling | Bcoleman6 | Building & Construction | 1 | 08-22-2008 03:29 PM |
| Fiberock install | STUPID | Flooring | 5 | 10-16-2007 07:29 PM |
