Can't Find Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2007, 03:37 PM   #1
Question
can't find pipe
Does anyone know where I can find 1 1/4" copper pipe type "L". We need 60' and can't seem to find it anywhere. Any suggestions would be appreciated.
medic9198 is offline   Reply With Quote
Old 09-23-2007, 06:42 PM   #2
Eibwen
That is a little odd size...
Why do you need that diameter??
Sammy is offline   Reply With Quote
Old 09-23-2007, 09:15 PM   #3
Custom Cabinet Maker
Lowes, plumbing supply. 1 1/4 not odd just not used too often. it is a standard sizei for return lines on single pipe steam systems. Just take a deep breath and try not to faint when you see price. I believe I paid almost 10 per foot at Lowe's
skymaster is offline   Reply With Quote
Old 09-24-2007, 03:02 PM   #4
Rewards Points: 150
Might want to try plumbing supply, not big box. And yeah, it's gonna cost you. I know that 1" L copper is ~$6 per foot around here.
scorrpio is offline   Reply With Quote
Old 09-25-2007, 03:52 AM   #5
We're reconnecting boiler pipes. Lowes doesn't carry it and will not order it. We're having trouble finding it online too.
Old 09-25-2007, 06:14 AM   #6
Rewards Points: 528
This site has copper L pipe, about $63.00 per 4 foot length.
http://www.plumbingsupply.com/copperpipe.html
Try this for your search:
"1-1/4 copper L pipe"
You should find other supplyers listed.
rjordan392 is offline   Reply With Quote
Old 09-25-2007, 09:34 PM   #7
Union HVAC Tech.
Where are you located? Every plumbing supply near me carries it. Why would you use "L" for a boiler system instead of "M"? I have several lenghts if you are close (NJ).
bigMikeB is offline   Reply With Quote
Old 09-26-2007, 03:48 AM   #8
Thanks for the help. How much do you have in NJ. I'm in MD
Old 09-26-2007, 09:07 PM   #9
Mike only reason for L would be on a steam system.OUCH OUCH wana guess why I know this? OW OW OW
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
