Can't Find My Filter! Carrier Unit. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 05:04 PM   #1
Can't find my filter! Carrier unit.
I moved into an older home that has what appears to be a 1995 or earlier model Carrier AC unit (model # CD5BXA060000AAAA).
For the life of me I can't figure out where the darn filter is located so I can replace it! Any help would be greatly appreciated.
I've attached a picture of the unit. Hopefully it shows up!
Thank you!
fishtex1973 is offline   Reply With Quote
Old 10-17-2013, 05:19 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
Remove both front doors. Inside there may be another set of doors that cover the fan, remove them. Inside there may be 2 washable or throw away filters.
Old 10-17-2013, 06:09 PM   #3
Rewards Points: 77
I don't believe the model number you provided is accurate. That looks like the number for the evaporator coil. Sometimes filters are installed in the return air grille(s) for convenience.
firedawgsatx is offline   Reply With Quote
Old 10-17-2013, 09:17 PM   #4
those gas lines
ahrens is offline   Reply With Quote
Old 10-18-2013, 08:47 AM   #5
Hvac Pro
yuri's Avatar
Beauties aren"t they.
Old 10-18-2013, 04:20 PM   #6
Rewards Points: 582
those gas lines are a joke.. where are the code requried dirt legs for starters ben sr
Old 10-18-2013, 05:10 PM   #7
Hvac Pro
yuri's Avatar
Probably in the crawlspace if at all.
That furnace one is ridiculous. If I tried some cr*ap like that where I am the only license I would have left in my wallet would be a drivers license.
Old 10-18-2013, 05:56 PM   #8
Rewards Points: 582
if you worked for me and did work like that I would take your drivers license too... ben sr
Old 10-18-2013, 06:25 PM   #9
Hvac Pro
yuri's Avatar
It's hard to find good help these days.
Old 10-18-2013, 06:39 PM   #10
Yeah, same here, if we tried that crap, id be out of a job pretty quick lol
The Following User Says Thank You to ahrens For This Useful Post:
ben's plumbing (10-19-2013)
Commercial roof top unit - which filter type? CamaLamaDD HVAC 3 05-24-2013 08:21 AM
non-ducted range vent filter on a ducted unit daluu Appliances 1 09-18-2012 07:52 AM
Carrier a/c unit model 58pav R J WARNER HVAC 6 08-29-2011 05:27 PM
Old carrier unit trouble hdbg62 HVAC 18 06-29-2011 08:57 PM
Carrier UNIT dcoleman HVAC 5 05-29-2011 04:34 PM
