Can You Use A 1.5 Ductless Condenser To Replace A 1.5 Ton Standard Condenser - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 02:56 PM   #31
Rewards Points: 154
mini-split
I dont think a transformer will solve all your problems Doc. If the question is whether the compressor will work I think the answer is yes. If its whether a 1.5-ton condensing unit will work with a standard low-voltage control for AC unit I would say maybee. If its going to remain a heat pump I would say you have some considerable control work to do. Not impossible but its definately not a drop-in replacement. Most definately not a do it yourself project.
Patrick Eubanks is offline   Reply With Quote
Old 05-03-2013, 10:28 PM   #32
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by beenthere View Post
For all practical purposes, yes it can do the same amount of cooling work.
winner!
Thanks.
Doc Holliday is offline   Reply With Quote
Roman Facut - Replace Delta w/American Standard mormegil Plumbing 1 11-29-2010 07:37 PM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 09:57 PM
Heat pump condenser fan missing: how do I know what to replace it with? Ptron HVAC 9 11-29-2008 12:46 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
