Can You Use A 1.5 Ductless Condenser To Replace A 1.5 Ton Standard Condenser - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 09:20 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
AC size/capacity is primarily determined by the cond coil size as it is fixed and never changes. Evap is important but we have seen 2 ton coils used for 1.5 ton systems etc so it can vary. In theory the comp has to pump a certain amount of vapor/heat into the cond and comps are rated for that/sized for that vapor. so a comp is a comp in BTUs/vapor capacity irregardless of body shape/style BUT the suction and discharge fittings will most likely be different sized/diameter so it won't work properly in a resi system. a mini split has different sized lines AND they and the 2 coils are exactly matched by the designer with NO variances allowed. the comp and coils and lines and lengths are all a designed pkg unlike your resi system which can mix and match lines and coils. if the suction line is too small on the mini comp then you won't get proper oil return etc. I would not try it.
Old 04-26-2013, 09:31 AM   #17
Experienced HVAC Tech
HVAC1000's Avatar
Yes it's pretty common in the south (especially Southeast like Florida to oversize the evap because it will have more surface area to condense water vapor on, thus dehumidifying. I'm not sure if you do that up in Canada though
HVAC1000 is offline   Reply With Quote
Old 04-26-2013, 03:01 PM   #18
Originally Posted by Doc Holliday View Post
I was thinking more along the lines of it may work, installing a mini split compressor into a regular residential condenser, as I would have to think 1.5 tons means 1.5 tons.
but this is new to me so I'm simply guessing here on a great topic, one I've never encountered before. are the compressors the same?
Thanks, my ideas are sometimes met with resistance from the status quo but I'm pretty good at pushing the envelope and bringing up topics that bring out new knowledge. I parted the compressor from the mini split and installed it. It is working and cooling. I'll give another update later once I've allowed more time for evaluating.
wonderworm is offline   Reply With Quote
Old 04-26-2013, 04:25 PM   #19
An old Tradesmen
Rewards Points: 6,112
Funny thing is. A smaller evap coil will remove more moisture then a larger one will. The larger coil is warmer.
Old 04-26-2013, 04:39 PM   #20
Hvac Pro
yuri's Avatar
Aw common now do we REALLY want to start getting into thermodynamics? will have to call up our old friend Clover to have a lively debate about compression ratio and COP and SEER.
Old 04-26-2013, 04:46 PM   #21
An old Tradesmen
LOL.
That big 50°F coil, can't pull the RH lower then 49% if your maintaining 70°F in the home.
Old 04-26-2013, 05:44 PM   #22
Hvac Pro
yuri's Avatar
we never use larger coils here BUT there are some pkgs where to get the utility rebate and perfect 16 SEER or whatever then they have to go with the larger physical size of coil in that tonnage. Lennox has A/B/C coils small/med/large and the larger ones are harder to fit in but need to be used for the rebates/AHRI approval. maybe it is an urban myth that a larger coils dehums better. had a great time with studying psychrometrics and all that baloney in school only to have a design engineer spec the job and pick everything anyway. once I retire I am going to really get into that design theory stuff when I have the time to do it.
Old 04-26-2013, 06:17 PM   #23
An old Tradesmen
It was somewhat nice when I was a manager and got to do design and builds.
Old 04-26-2013, 06:33 PM   #24
Hvac Pro
yuri's Avatar
yeah it is real interesting. I have a steam ticket and we had to study turbines and engines and I was rebuildin cars when I was 6 and handin the ole man wrenches. that's how you learn how stuff works.
Old 04-26-2013, 06:40 PM   #25
An old Tradesmen
I use to go to the garage where my dad worked when he worked late on Tuesday nights and help him when I was a young kid.
Old 04-26-2013, 07:15 PM   #26
Hvac Pro
yuri's Avatar
Yep. I used to rebuild carbeurators, change clutches and pressure plates with him and laid on my back on a frozen floor. gets cold where I am. had a big wood box stove and country music blaring, Good Times.
Old 04-26-2013, 09:24 PM   #27
Rewards Points: 582
country music blaring...is there any other kind ben sr
Old 05-02-2013, 05:56 PM   #28
HVAC Tech
Jim-Martin's Avatar
A quick answer
Most ductless condensers use Line Voltage and not 24 volt control voltage to cycle the outdoor unit. In which case the answer would be NO.
Have a nice day,
Jim Martin
Last edited by beenthere; 05-02-2013 at 08:07 PM. Reason: Removed link to company website in post
Jim-Martin is offline   Reply With Quote
The Following User Says Thank You to Jim-Martin For This Useful Post:
Doc Holliday (05-02-2013)
Old 05-02-2013, 11:21 PM   #29
I'm Your Huckleberry
Rewards Points: 2,270
Have a nice day,
Jim Martin
okay, get a transformer so the answer is now yes. but the real and still standing question is "will a 1.5 ton mini split compressor do the exact same job as a 1.5 ton , oh, let's say Copeland Scroll 1.5 ton compressor?"
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-03-2013, 05:40 AM   #30
An old Tradesmen
For all practical purposes, yes it can do the same amount of cooling work.
Roman Facut - Replace Delta w/American Standard mormegil Plumbing 1 11-29-2010 08:37 PM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 10:57 PM
Heat pump condenser fan missing: how do I know what to replace it with? Ptron HVAC 9 11-29-2008 01:46 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
