can you tell what stage your furnace is running in?
Yep every time. The lower fan speed when it comes on is 1st stage, higher fan speed is 2nd stage. As for the Single stage thermostat, the computer on the furnace circuit board is doing all of the work to determine what stage. Where as with a two stage thermostat, the thermostat would be doing the work to determine when to ramp up or down.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
