Can You Run A Heatpump With W8835 Envirazone With IAQ TH9421 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 09:45 AM   #1
Rewards Points: 392
Can you run a heatpump with W8835 Envirazone with IAQ TH9421
My friend just got a new house that uses the W8835 Envirazone with IAQ TH9421 thermostats. I was reading through the manual and it says it supports a heat pump, but I can't seem to figure out how you'd do the cutoff temperature control. Would you have to use an outdoor temperature shutoff that doesn't have any control from the thermostat?
I have a heatpump with the vision pro8000 and I love being able to set the cutout temp and see the outdoor temp. I actually use the outdoor temp more then the heatpump does..
Since these IAQ stats only have 3 wires, how would you connect the outdoor thermostat to these?
What are the options in this case?
Thanks,
Jeff
zootjeff is offline   Reply With Quote
Old 05-09-2010, 10:34 AM   #2
Rewards Points: 392
It looks like maybe this is all that's needed?
1. Install outdoor sensor and run the wire in the garage to the outdoors (PN: C7089U1006) (~20 min + ~$20 material)
2. Install the outdoor sensor module right next to your zone control box (PN: 50022037-001) (~5 min + ~$20 material)
http://customer.honeywell.com/techli...69-2043EFS.pdf
-Jeff
Old 05-09-2010, 02:45 PM   #3
An old Tradesmen
Rewards Points: 6,824
The outdoor sensors wire to the Enviropanel.
Are you going to zone your system.
Old 05-09-2010, 09:33 PM   #4
Rewards Points: 392
This is a brand new house, they have an upstairs and downstairs zone with dampers. They have the back yard plumbed and wired for AC but no AC or HP installed. I want to figure out if their system would support a heat pump.
I think I need the module and the adapter. There is no temp sensor wiring on the zone control unit.
Old 05-10-2010, 06:19 AM   #5
An old Tradesmen
Sorry. You do need the module. Was thinking of a different panel.
It wires to the enviro panel.
The panel has 4 buses. Connect it to one of the buses not used for a thermostat. The module will identify itself to the panel.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
