Can You Replace A 1+pole Contactor With A True 2 Pole? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 07:39 AM   #1
Can you replace a 1+pole contactor with a true 2 pole?
Can you replace a 1 +pole contactor(some people call them a double pole w/single throw or Single pole with Shunt) with a true 2 pole contactor?
Why do the manufacturers still use a 1+pole?
ashton is offline   Reply With Quote
Old 05-12-2010, 04:21 PM   #2
Here is a picture of the 1+ pole contactor. Why couldn't you use a 2 pole?
Old 05-12-2010, 04:58 PM   #3
An old Tradesmen
Rewards Points: 7,346
On 1,000,000 units built. Saving 50 cents per contactor adds up.
Old 05-12-2010, 05:08 PM   #4
I take it that means you can replace them with a 2 pole? I ordered the same 1+ contactor but would have preferred a 2 pole because if something goes wrong I dont have to worry about frying compressor or fan.
Old 05-12-2010, 05:17 PM   #5
An old Tradesmen
You can. But. Some contactors are wired up to control the on off of crank case heaters. So you have to watch that you don't wire them up wrong.
Actually. More of a chance of something going wrong with a 2 pole contactor. Then a single pole contactor.But you can use a 2 pole in place of a single pole.
Old 05-12-2010, 09:04 PM   #6
30 year tech
hvac122's Avatar
It was told to me some years ago that the manufactures are using the capaciter as a off cycle crankcase heater of some sort hence the single pole contactor. I would replace with whatever is there originally.
If I remember right it was Comfortmaker tech service that told me this.
hvac122 is offline   Reply With Quote
Old 05-12-2010, 09:24 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
I thought I heard that too. Guess we'll have to put an amprobe on the next one we run into.
Old 05-12-2010, 10:03 PM   #8
An old Tradesmen
Some are doing that, others aren't.
Old 05-12-2010, 11:40 PM   #9
Houston204's Avatar
Rewards Points: 556
I've seen Carrier use single pole contactors to energize the crank case heater this way.
240 volts is present across the open contacts of a single pole contactor...
Houston204 is offline   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
