Can You Bypass Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 10:08 AM   #1
Can you bypass thermostat?
A few months ago the electric went out for 3 days. I have a gas hot water baseboard heat. The thermostat runs by electric Thus we had no heat. Is there a way to fool the heater into coming on?
drozman is offline   Reply With Quote
Old 03-10-2012, 10:15 AM   #2
Rewards Points: 1,522
No, gas valve and sensors on the unit are fed by electricity so it wouldn't light.
bob22 is offline   Reply With Quote
Old 03-10-2012, 11:49 AM   #3
biggles's Avatar
if you had a steam boiler with a pilot generator...yes http://www.bestbuyheatingandaircondi..._Code=PIL9A41L
Old 03-10-2012, 11:58 AM   #4
Rewards Points: 1,192
An electric recirc pump?
bobelectric is offline   Reply With Quote
Old 03-10-2012, 12:14 PM   #5
An old Tradesmen
Rewards Points: 6,108
Back up generator.
Old 03-11-2012, 03:22 AM   #6
how
Rewards Points: 1,070
A hot water tank connected to baseboards can gravity and convection feed the baseboards in a power outage with the zone valve manually opened and with the right plumbing set up.
Older gravity feed boilers also don't require anything beyond their own millivolt production to work and are never connected to the electric grid.
Likewise with Biggles steam boiler.
But nothing that uses 120V for pumps or 24 volts for the gas valve & controls will work with a thermostat bypass.
how is offline   Reply With Quote
Old 03-11-2012, 06:58 AM   #7
Rewards Points: 1,214
You need to fool more than the thermostat to get heat.
COLDIRON is offline   Reply With Quote
Old 03-11-2012, 07:53 AM   #8
Happy to help
Lighting Retro's Avatar
Originally Posted by beenthere View Post
Back up generator.
this is the best choice, but obviously not always an option.
Lighting Retro is offline   Reply With Quote
Old 03-11-2012, 08:24 AM   #9
biggles's Avatar
get 10A/115V off a car battery with the car running... if the outside temps are below 32F http://www.northerntool.com/shop/too...2345_200422345
Old 03-11-2012, 10:09 AM   #10
Rewards Points: 292
Checking out the above site, and others, they show operation by plugging 'appliance' into the inverter.
One site's FAQ suggested running an extension cord from the garage to the (home) appliance. I suspect, not a good idea.
But, how about going one step further? Since (my) extra car sits in the garage, why not FIRST throw the main disconnect, then with a short heavy duty extension cord (2 plugs), plug into a nearby outlet.
Wouldn't that make the full output of the inverter 'available' to that leg of the system; enough to power a refrigerator, freezer, and a VS furnace? Could the combined LRA of the refrigerator and freezer be a problem?
Also, the pictures appear to indicate that the inverters have one socket. Any of the units (say, up to 5000W) have multiple sockets? That way, one could divide the load between the 2 power legs if needed.
How 'clean' is the AC voltage, anyway?
veesubotee is offline   Reply With Quote
Old 03-11-2012, 10:19 AM   #11
An old Tradesmen
Running off of a car battery, the car's alternator won't produce enough wattage to run more then one medium sized appliance. So you are limited to less then 1,000 watts, for any length of time over a 15 minutes. A 1000 watt inverter may not be able to start a furnace blower.
Old 03-11-2012, 02:32 PM   #12
Rewards Points: 292
On the site (previously linked), a video showed a 5000W unit.
Just a thought anyway. Car never gets used. With a full tank, I'd be good for quite a while.
Old 03-11-2012, 03:04 PM   #13
An old Tradesmen
The car alternator wouldn't keep after. Your battery would be drained fairly quickly.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
manual bypass for furnace thermostat. foxsam HVAC 8 11-07-2008 01:20 PM
