Can A Trane Xe80 Do Fan Only? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2008, 04:46 PM   #1
Can a Trane xe80 do Fan only?
Hello
I need to move air in my house in the winter when I am using a woodstove. Most of the heat stays in the family room where the stove is. My current Honeywell thermostat is heating only. I want to use the fan in the furnace to move the air and heat around in the house.
If I get a heating and cooling thermostat and connect the Y and G wires on both ends, will it work?
Fred k.
Fredmickey is offline   Reply With Quote
Old 09-12-2008, 08:14 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Does this furnace have a circuit board (PC style)?? If so, it should have a 'G' terminal. Connecting 'R' to 'G' (via a jumper wire) will turn on the blower (constant run).
To answer your question of "If I get a heating and cooling thermostat and connect the Y and G wires on both ends, will it work?" No...not Y & G,(maybe I mis-understood your concept) but yes you can get it to work but you need a third wire in your t-stat cable from the furn to the stat. If you have a 2 wire run now, you can replace it with a 3 or 4 (or more) wire cable. Probably what you have is 18/2 wire, and you'll probably find 18/4 at your local store....and a heat/cool stat that you like.
What you would do:
Replace the stat and the cable with new.
At the furnace: Connect red to R, white to W and green (or blue...depends what it has) to G. That should leave a yellow left over (which you can just cap off if you don't have AC. No need to cut it short, just cap it).
At the stat: same wiring...red to R, white to W, green to G. You can tuck the yellow or hook it up...doesn't matter.
The function of the terminals: R supplies 24V out. When the furn gets that 24V back on W, it starts heat mode. On G, it turns on the blower(constant run), on Y it starts cool mode. Y & G are basically the same at the furnace, but they are not at the stat.
Trane XE80 (Pressure Switch Indicator Err) cherande HVAC 7 09-25-2008 12:02 AM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 12:16 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
