Can A Takeoff Be Installed Out Of The Top Of The Plenum? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 05:34 PM   #1
Can a takeoff be installed out of the top of the plenum?
Recently purchased a house that was added onto a few years back.The new addition cools just fine but the original structure is at least 6 degrees warmer.Was wondering if I could add another duct from the top of the plenum as all four sides are being used?If not, then how could I go about resolving this isssue?Thanks
terrywoo is offline   Reply With Quote
Old 07-16-2011, 05:42 PM   #2
JJboy's Avatar
To add another duct, you need to increase your AC tonnage......to get this right, you need to redo all load calculation etc. Is not just add more ducts.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-16-2011, 06:19 PM   #3
vln
Underwriter
Could try increasing the fan speed, it may not have been set for max speed when they installed the furnace.
vln is offline   Reply With Quote
Old 07-16-2011, 09:23 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
It sounds as if you've already done the work if the rest of the home is all of a sudden 6 degrees warmer. Oops.
Static pressure is the issue when dealing with plenums. If you open up the rear by adding a duct and especially a bigger sized one you lose pressure everywhere else as the air flows to the easiest path possible, in this case straight out the back. The only excpetion I'll personally make when I have no other absolute choice is if it's a 4" or 5" duct to a very small room such as a restroom and even then if the air flow remains good throughout the home I still don't like. And I always put it in a corner, not the middle.
You should stay 6" from the top or end cap rather and 6" in from the side that attaches to the evaporator coil for best results (scientifically speaking) and duct takoffs should be criss crossed from one another so not directly opposing.
Not mandatory but good practice, the latter sentence.
Good luck.
Doc Holliday is offline   Reply With Quote
Old 07-17-2011, 06:59 AM   #5
Rewards Points: 1,216
I would cut back on the airflow to the new addition and see if I could add More air to the existing and I would check my returns, got to have adequate return air also
Oh check thermostat location also. So many things to check.
COLDIRON is offline   Reply With Quote
Old 07-17-2011, 07:16 AM   #6
An old Tradesmen
Rewards Points: 6,870
yep, damper back the addition.
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
plenum splitter design & linkage rebar HVAC 8 01-19-2010 07:18 AM
Can doors installed brick be reversed FuLLTiLT Building & Construction 7 01-10-2010 07:52 AM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 09:53 AM
Just installed LG dishwasher--there's a buzzing sound. naiLS1 Appliances 1 04-15-2007 09:22 AM
