Can Return Air Be Too Large? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 09:33 AM   #1
can return air be too large?
My single floor 2600 sf house has the air handler room centrally located with 2 floor level wall registers: one in the hallway leading to the bedrooms and one in the living room.
The hallway register is 400 sq in and the living room is 240 sq in. The air handler is a Goodman aruf486016ba with capacity on high of 1985 cfm.
I'm considering replacing the current solid door with a louvered door which would add, at a minimum, another 800 sq in of return air. Is that too much of a good thing?
The unit is mounted on a 36 in square pedestal with 3 12x30 filters. I am also considering raising the pedestal so I can use filters on the order of 20x30 just to be less restrictive. Opinions?
Peyton
peyton is offline   Reply With Quote
Old 07-14-2010, 11:44 AM   #2
An old Tradesmen
Rewards Points: 7,770
Shouldn't be a problem. Although it will probably give you better return. Its doubtfull that your supply is big enough that it would allow for too much air flow.
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 12:01 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 06:26 PM
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
