Can Range Hood And Water Heater Vent Share Same Roof Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 03:11 PM   #1
huynh's Avatar
Can range hood and water heater vent share same roof vent?
Dear all,
I am installing a range hood and trying to vent it out (the old one pushes the air back into the room!) On the other side of the kitchen is the water heater that already has a vent going up the roof. Can I just connect the range hood pipe into the already-there pipe of the water heater?
Also, the range hood has a duct of 7 in. diameter. The water heater pipe is only 3 in. wide. Should I wide the whole pipe system 7 in. wide up to the roof?
I am new and this is my first post. Any idea to help would be deeply appreciated. Thank you very much!
huynh is offline   Reply With Quote
Old 09-08-2010, 03:21 PM   #2
fabrk8r
fabrk8r's Avatar
No. It's against building code and mechanical code and it isn't safe.
Read this thread: Can bathroom exhaust and dryer share same outside duct?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-08-2010, 03:40 PM   #3
No, they have to be seperate.
amdspitfire is offline   Reply With Quote
Old 09-08-2010, 03:56 PM   #4
huynh's Avatar
Thank you for such fast replies!
Yes, I will build a separate vent for the range hood.
Tags
pipe , range hood , roof vents , water heater
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Plugging Range Vent in Attic SPS-1 HVAC 1 12-08-2008 10:40 AM
Securing vent hood to top of water heater? darsunt HVAC 1 07-01-2008 08:59 PM
