Old 01-30-2012, 04:41 PM   #1
Can PVC be used to vent a Dryer
I have a second floor laundry that currently has an aluminum exhaust vent. I was wondering if I can use pvc to vent the dryer so that I can easily install clean-outs (I haven't seen anything that will allow easy access in the aluminum round ducts that I currently have in place). The exhaust line is about 12 feet long with two 90 degree elbows. I am concerned about lint in the line (the dryer is gas) and would like to put in clean-out "y's" to vacuum the lint periodically.
Sdeclara is offline   Reply With Quote
Old 01-30-2012, 04:48 PM   #2
Part of the Clover Leaf
No. The lint flowing thru the PVC will statically charge it making the lint stick to it like a magnet.
hvac5646 is offline   Reply With Quote
The Following 3 Users Say Thank You to hvac5646 For This Useful Post:
Hardway (01-30-2012), plummen (01-30-2012), Sdeclara (01-30-2012)
Old 01-30-2012, 05:01 PM   #3
Hvac Pro
there are aluminum "saddle tees" that we use to connect gas water heaters to the side of a main vent pipe which you may be able to buy from a sheet metal shop or possibly HDepot. DO NOT use sheet metal screws as they catch lint, use foil metal tape from HDepot. Looks like this one except the branch part is connected to the body at a 45 deg angle.
Old 01-30-2012, 05:51 PM   #4
Jack of all - master none
hyunelan2's Avatar
I second this statement. Never thought about that until an inspector almost failed me when I did my laundry room in the basement. He let me pass as long as I took out the screws while he stood there inspecting other things.
hyunelan2 is offline   Reply With Quote
Old 01-30-2012, 06:12 PM   #5
as seen on tv
You can use 4" worm drive clamps at the service end makes it nice for quick cleaning
qbert is offline   Reply With Quote
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing 4 07-27-2010 11:39 PM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
