Can An Outdoor Temp Indicator Be Added To My Tstat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 12:14 PM   #16
Rewards Points: 150
Originally Posted by chris75 View Post
The north side will be the most accurate temp reading, most if not all sensors will recommend this location.
OK? still don't understand why.
My northside would be my neighbors southside. Not sure why the temperature would be any different right across the road...if he decided to install one on his southside, I would think it would read the same as one installed on my Northside....oh well.
Key1
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Old 12-14-2008, 12:24 PM   #17
An old Tradesmen
Rewards Points: 8,154
The sun, doesn't shine on the North side in most of North America.
So your North side would be shaded, but his South side would have sun light shining on it.
Old 12-14-2008, 12:46 PM   #18
Rewards Points: 150
Now that I get. I had thought it was something beyond the elements since I had mentioned putting it in a location protected from the elements.
Now that I think about it, I guess the sun would still be heating the air around that shaded location.....Northside it is.
Key1
Old 12-19-2008, 07:04 PM   #19
Rewards Points: 150
All done!!
The "Outside Temp" sensor was successfully installed.
Thanks for your assistance
One small detail I did not forsee.
When the outdoor temperature is displayed, it appears in the window where the indoor humidity was displayed. Now I no longer have humidity displayed........ But given the choice I prefer the outside temp displayed since I have a seperate near by hygrometer which displays the humidity.
Key1
Old 12-19-2008, 08:08 PM   #20
Electrician
Just for giggles, where did the sensor instructions want the sensor located?
chris75 is offline   Reply With Quote
Old 12-19-2008, 09:55 PM   #21
Rewards Points: 150
I'm looking at the instructions now.
"Honeywell C7089 Outdoor Sensor".
No mention about installing on North Side.
Exact instructions are in blue font below
"Location and Mounting
Mount the sensor wire where:
  • it cannot be tampered with
  • there is good air circulation
  • it can measure true outdoor ambient temp
  • surface is flat
  • wire distance between sensor and tstat is less than 200 ft.
Do not mount the sensor
  • in direct sunlight
  • where hot or cold air blow on the sensor, near discharge from an outdoor compressor, or outdoor vent
  • where snow, ice, or debris can cover it. "
There was also a figure showing it mounted under a roof eave.
Key1
Old 12-19-2008, 10:00 PM   #22
Rewards Points: 150
You da man! Latley, I've been running 10 conductor to t-stats, if its in the budget anyway, gives lots of options in the future, outdoor sensors, indoor sensors, humidistat, and dehumidistat control.....
Also,
the sensor instructions as well as the tstat instructions both indicated that a "seperate" cable should be used to wire the sensor. It should not be wired using the same cable as the other wires connected to the tstat.
If those instructions are followed, the 10 conductor cable could not be used to install the sensor.
Key1
Old 12-19-2008, 10:50 PM   #23
Electrician
Originally Posted by key1cc View Post
Also,
Key1
Yeah, I've read that also, but its usually too late.
Old 12-23-2008, 10:33 PM   #24
Rewards Points: 150
I should have listened to the Pro's
Well, having the hard head that I do, I decided to take the easy route and install my temp sensor in back of the house using the hole already made for the AC lineset. This happens to be the south side of the house and all was fine on the cloudy day that I installed it.
Well we got some sunshine the other day and eventhough my sensor is under a roof eave protected from direct sunlight, the temperature was registering 35F even though it was 19F outside.
Apparently, the nearby air that is located in the sun is heated enough to influence the air by the sensor which is not directly in the sun, giving the false reading. I thought after reading the directions to position it out of direct sunlight I would be ok.....
I really don't want to locate it on the north side because that is the front of the house and there really is not a good location that would not stand out.... oh well.....
Key1
Old 12-23-2008, 11:13 PM   #25
Key1
All you have to do is hit the more key 2 times and bam theres your humidity.
integlikewhoa is offline   Reply With Quote
Old 12-24-2008, 10:20 PM   #26
Rewards Points: 150
8 months later and I'm still learning about my Tstat
Thanks for sharing that useful bit of knowledge.
Key1
Old 12-25-2008, 01:00 AM   #27
Key1
No problem. And I got another you probley didnt know.
On the top right coner press three times and hold it down.
A tooth pick, 2 blades, both a phillips and flat screwdriver and scissors pops out the side.
Old 12-25-2008, 09:04 AM   #28
Rewards Points: 150
Here is a pic of my Tstat.
The top right hand corner just takes the temp up....
Please elaborate..
Key1
Old 12-25-2008, 11:48 AM   #29
Sorry that was suposed to be a joke, did you really want a toothpick?
Old 12-25-2008, 12:00 PM   #30
Rewards Points: 150
oh..
now I get it...you are implying that a "hack" had inadvertantly left those items inside the tstat during installation. Quite humerous.
Anyway, I do know some other tstat tricks, like making the redlight come on when ever there is a call for 1st stage heat (or 2nd stage heat, or cooling)...no joke.....it's a very nice Tstat.
Key1
TSTAT changeout help walker45 HVAC 9 12-08-2008 10:25 AM
I want to learn about tstat wires... thealexdexter HVAC 1 12-06-2008 11:23 PM
Insulation Added in small attic & stuff organized jamiedolan Project Showcase 3 10-17-2008 10:31 AM
Tstat bad or what walker45 HVAC 1 03-10-2008 09:54 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
