Can An Outdoor Temp Indicator Be Added To My Tstat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2008, 10:36 AM   #1
Rewards Points: 150
Can an outdoor temp indicator be added to my Tstat
I have a Trane themostat TCONT803A53DAA also known as a Honeywell TH8321U1030. Does anyone know if i can wire it to an outdoor temperature monitor or sensor....so i can see the outside temp right on the indoor tstat display (not to control anything, just for viewing).?
Thanks in advance
Key1cc
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Old 12-13-2008, 10:47 AM   #2
Electrician
Look at the owners manual, I didnt feel like searching for it online.
chris75 is offline   Reply With Quote
Old 12-13-2008, 11:38 AM   #3
An old Tradesmen
Rewards Points: 8,236
Yes you can.
Since its dual fuel capable, it has terminals for an outdoor sensor.
Old 12-13-2008, 02:01 PM   #4
Rewards Points: 150
Thanks for the quick feedback.
My installation manual does indicate that I have an installer "set up number" for it in the installation menu on the Tstat.
I'ved already ordered the item in the attached link.
http://www.prothermostats.com/produc...product=109923
Thanks again.
Key1
Old 12-13-2008, 02:46 PM   #5
An old Tradesmen
No problem.
Old 12-13-2008, 07:37 PM   #6
Electrician
Hopefully you have extra conductors at the t-stat so you dont have to snake any new wires...
Old 12-13-2008, 07:57 PM   #7
Rewards Points: 150
When I snaked the new 8 wire cable through with the new installation, I left the old 3-wire and 2-wire set in place inside the wall in case I ever needed them. For this application I will use the two wire cable because I beleive two are required. I will continue to leave the old 3 wire cable in the wall for future use....who knows what they may come up with next.....
Key1
Old 12-13-2008, 08:27 PM   #8
Electrician
Originally Posted by key1cc View Post
When I snaked the new 8 wire cable through with the new installation, I left the old 3-wire and 2-wire set in place inside the wall in case I ever needed them. For this application I will use the two wire cable becase I beleive two are required. I will continue to leave the old 3 wire cable in the wall for future use....who knows what they may come up with next.....
Key1
You da man! Latley, I've been running 10 conductor to t-stats, if its in the budget anyway, gives lots of options in the future, outdoor sensors, indoor sensors, humidistat, and dehumidistat control.....
Old 12-13-2008, 08:55 PM   #9
Rewards Points: 150
Nawww, you da man!
We shall see what occurs once the sensor arrives. I'm not sure where to locate it. Maybe in the outdoor unit or under an eave or something.
Key1
Old 12-13-2008, 10:29 PM   #10
Electrician
Nawww, you da man!
Key1
Normally the north side of the structure is the best location.
Old 12-14-2008, 05:23 AM   #11
An old Tradesmen
Use the 3 conductor.
Take the third wire, and wrap it around the sheathing on the bundle. It acts like a sheild, and protects against electrical interference from the other wires in the wall.
Old 12-14-2008, 08:22 AM   #12
Rewards Points: 150
Really?? Why is that? If protected from the sun, wind, rain, snow, and elements.....what differece would it make
Key1
Old 12-14-2008, 08:29 AM   #13
Rewards Points: 150
Excellent advice as usual BT
Will do.
Key1
Old 12-14-2008, 10:24 AM   #14
Yeah Chris, it's Sunday for gosh sakes
hvaclover is offline   Reply With Quote
Old 12-14-2008, 11:43 AM   #15
Electrician
Key1
The north side will be the most accurate temp reading, most if not all sensors will recommend this location.
TSTAT changeout help walker45 HVAC 9 12-08-2008 10:25 AM
I want to learn about tstat wires... thealexdexter HVAC 1 12-06-2008 11:23 PM
Insulation Added in small attic & stuff organized jamiedolan Project Showcase 3 10-17-2008 10:31 AM
Tstat bad or what walker45 HVAC 1 03-10-2008 09:54 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
