#1 |
Can a natural gas furnace go on a plywood floor?
As part of a basement renovation, I'm planning on putting down 1.5" foam sheeting covered by 5/8" plywood onto my cement slab.
I have a natural gas furnace (not a stove)--can I place the gas furnace directly on the plywood, or must it go on some sort of non-combustible surface? Note: The furnace is pushing the air up vertically. If you could reference a rule/building code/etc., I would appreciate it. Thanks. |
| Tags |
basement, combustible, furnace, gas, plywood ![]() |
| Display Modes | |
| Seal Peel and Stick Tiles? | Echo1 | Flooring | 21 | 06-22-2012 10:07 PM |
| Have an oversized furnace | turfgrass | HVAC | 5 | 02-22-2010 04:48 PM |
| Problems with new furnace..Overheating, having to reset. Furnace too big? | Tommy2 | HVAC | 41 | 12-01-2008 02:55 PM |
| Could installing a furnace to the floor joists cause the floor to slope? | JKL | HVAC | 5 | 01-03-2007 10:23 PM |
