-   -   Can a natural gas furnace go on a plywood floor? (http://www.diychatroom.com/f17/can-natural-gas-furnace-go-plywood-floor-72551/)
toddmanqa 06-01-2010 10:02 AM
As part of a basement renovation, I'm planning on putting down 1.5" foam sheeting covered by 5/8" plywood onto my cement slab.
I have a natural gas furnace (not a stove)--can I place the gas furnace directly on the plywood, or must it go on some sort of non-combustible surface?
Note: The furnace is pushing the air up vertically.
If you could reference a rule/building code/etc., I would appreciate it.
Thanks.
beenthere 06-01-2010 02:38 PM
If its not UL rated to be set on combustible flooring. Its not permitted by any code.
So you need to look at its install manual to find out.
