Can This Be Moved Closer To The Beam? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 11:04 AM   #1
Trucon01's Avatar
Rewards Points: 510
Can this be moved closer to the beam?
Hi All,
I'm in the process of re-doing the basement and was wondering if it would be possible to move the long run on the ceiling closer to the steel beam?
If you need more pictures, please let me know.
thanks.
Can this be moved closer to the beam?-photo.jpg   Can this be moved closer to the beam?-photo-2-.jpg   Can this be moved closer to the beam?-photo-3-.jpg   Can this be moved closer to the beam?-photo-4-.jpg   Can this be moved closer to the beam?-photo-1-.jpg
Trucon01 is offline   Reply With Quote
Old 02-05-2012, 11:10 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If you are talking about the main trunk I would say yes
You would just need to have a transition made up. You may need to cut down some of the trunk length to get the transition in. Then just reattach the branch ducts. The side take off I think could be done with top take offs cleaning it up some more
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
plummen (02-05-2012)
Old 02-05-2012, 11:14 AM   #3
Trucon01's Avatar
Rewards Points: 510
Thats great news. I was just concerned it couldn't because it runs straight out from the furnice unit... Do you have a rough estimate of what something like that would cost?
Old 02-05-2012, 11:18 AM   #4
Rewards Points: 560
Sorry I don't and I don't know what typical costs are in your area.
If you need rough cost you can contact a local HVAC company there where you live. Most companies can build you the transition and you can do the work. More than likely with this transition it will be two pieces.
If you are not planning to do the work yourself then get a couple quotes and go from there
Good luck
Old 02-05-2012, 11:20 AM   #5
Trucon01's Avatar
Rewards Points: 510
I really appreciate your time getting back to me!!
Old 02-05-2012, 11:21 AM   #6
Rewards Points: 560
Glad to help
Old 02-05-2012, 07:41 PM   #7
Trucon01's Avatar
Rewards Points: 510
Hi again...
In the first picture, it shows the duct work to my floor registers.. None of the duct work is taped, just screwed?? How bad is that?
Also, in the second picture, it shows a black PVC pipe going into the cement floor. What is this for? I don't think its a drain pipe?
Can this be moved closer to the beam?-photo-6-.jpg   Can this be moved closer to the beam?-photo-7-.jpg
Old 02-05-2012, 07:44 PM   #8
Rewards Points: 560
We alway tape all joints it reduces any air loss.
In the 2nd pic it looks like a drain stack. Above the pipe is there a kitchen or bath?
Old 02-05-2012, 07:44 PM   #9
Rewards Points: 13,960
Looks like a drain to me. Go outside and see if that pipe does not go all the way up throught the roof to also act as a vent pipe.
Plumber101 (02-05-2012)
Old 02-05-2012, 07:51 PM   #10
Trucon01's Avatar
Rewards Points: 510
The first picture is another view of the PVC pipe...
There is no kitchen or bathrooms above this pipe. It looks like it travels with the HVAC truck up to the second / third floor
The second picture show the drain where I hear water.. The kitchen and one upstairs bathroom are above this pipe...
Can this be moved closer to the beam?-photo-4-.jpg   Can this be moved closer to the beam?-photo-5-.jpg
Old 02-05-2012, 07:54 PM   #11
Rewards Points: 560
Then the kitchen or bathroom or both may drain into this 3" pipe.
What are you getting at? You want to move this pipe?
Old 02-05-2012, 07:57 PM   #12
Trucon01's Avatar
Rewards Points: 510
No, figured since I was posting pics of the duct work, I'd ask what that was. My dad thought it was something to do with Radon? But I can buy a vent pipe which would lead to the roof
If you feel like watching my demo project, feel free to view 2012 - Basement demo
Thanks guys
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
