Old 03-01-2009, 02:05 AM   #1
Can I vent horizontial out a side wall?
Hello,
Can I vent an 80% eff furnace out of a side wall? I'll follow the 1/4" per foot in the horizontial, then elbow once out past the wall - up four to five feet (or whatever the height requirement is) - so that the top of the "chimmeny" meets the required height above the roof.
myselftwo is offline   Reply With Quote
Old 03-01-2009, 06:11 AM   #2
the Musigician
DangerMouse's Avatar
i THINK the lowest you can vent through a wall is 92% from my understanding. they make them with squirrelcage blowers to move a ton of exhaust fast. i don't think 80% would be acceptable, but what do i know? i just commented so i'd see any other answers as i'm curious now....
lots of good HVAC guys here... they should be along any time to poopoo me and give you a better answer. lol
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-01-2009, 09:18 AM   #3
GC/Master Plumber/Mech
Depending on your code but most will allow to come out a side wall and then go verticle to provide proper draft.
It would be wise to check with your local codes department.
I would say yes but not terminate at a horz.
Old 03-01-2009, 09:52 AM   #4
Hvac Pro
You can have a external B vent chimney but it must be supported properly and encased and done by a professional chimney co. to code. Most people don't as it is expensive and ugly. If the furnace is getting older it may be more cost effective to go with a high efficiency furnace and use plastic venting.
Old 03-01-2009, 06:43 PM   #5
HVAC / Plumbing
Don't know if it's same in every area. Where I am . If you go outside & up the side of the house with B vent. A insulated chase must be installed around the B vent
kenmac is offline   Reply With Quote
Old 03-01-2009, 09:32 PM   #6
tk03's Avatar
The use of "B" vent outside the structure is not allowed by the "B" vent manufacturers unless insulated and boxed in.
Check with the furnace manufacturer to see the venting options. They have the only say in venting if not a class 1 appliance(chimney vented).
tk03 is offline   Reply With Quote
Grinder / Ejector Pump - vent to side of house? dadruz Plumbing 2 01-14-2009 04:57 PM
Thru wall vent question phillyexplorer HVAC 5 10-11-2008 10:50 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
attic ventilation design help Noreaster Roofing 15 04-30-2008 09:31 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
