Can I Vent Furnace Through Window? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 04:26 PM   #16
An old Tradesmen
Rewards Points: 6,826
Post the brand and model number of your furnace.
Old 09-22-2010, 07:09 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Originally Posted by hvaclover View Post
thy are called direct fire WHs
Who love's 'ya RED?????
Hey cool, first time I see these. Now that's awesome. I will look into this when I have spare money to stop my rental.
Old 09-22-2010, 07:26 PM   #18
Keeprite forced air furnace model CUGE075BG01
praprade is offline   Reply With Quote
Old 09-22-2010, 07:40 PM   #19
An old Tradesmen
Thats a negative draft furnace. So you'll need a power venter to vent it horizontal/side wall.
Old 09-22-2010, 07:49 PM   #20
So I am guessing it would cost me around the same as changing liner ?
Old 09-22-2010, 08:05 PM   #21
An old Tradesmen
Probably.
Might want to find out whats blocking your liner now. Might be easy to remove.
Old 09-22-2010, 08:18 PM   #22
HVAC / Plumbing
I guess he could go out the window & above the roof line Provided horizontal run isn't too long. Or, is he just wanting to terminate the horizontal run out the window ?
kenmac is offline   Reply With Quote
Old 09-22-2010, 08:19 PM   #23
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Before you spend a lot of $$ on chimney repairs you may want to get the heat exchanger carefully checked for cracks and popped compression rivets. Very high rate of failure on those. May fail soon. Your brother with the no chimney high efficiency furnace is better off.
Old 09-22-2010, 08:35 PM   #24
HVAC / Plumbing
I Install a 90 % for about the same $ or less than it cost to line a chimney
Old 09-22-2010, 10:55 PM   #25
Thanks guys. I will just went it out through the window ,hope to survive this winter like that and if I do,quit Canadian dream ,sell house and move back to Cyprus .
Thanks again
Old 09-23-2010, 02:36 AM   #26
Nai---sigarou
If you mean the island of Kypros I don't think so
hvaclover is offline   Reply With Quote
Old 10-04-2010, 08:10 PM   #27
So I got on the top of the house . Liner was broken like 2 meters from the top and squirrels nest and insulation was blocking it . I found big vacuum cleaner with long hose ,pulled it on top of the house and cleaned garbage from chimney . Than cleaned whatever fell at the bottom so it's working now. It should be ok for this winter and hopefully before next one comes I will have enough money to rebuild chimney and put new liner .
Thanks again for all the help .
Old 10-04-2010, 09:02 PM   #28
Hvac Pro
yuri's Avatar
Buy yourself 2 good CO Carbon monoxide detectors. Put 1 in the basement and 1 by your bedroom in case the chimney gets blocked again or collapses. Concerned about your safety. People die from that stuff, get brain damage and I know of a collapsed chimney incident where several people are in permanent comas.
The Following User Says Thank You to yuri For This Useful Post:
Tom Struble (10-05-2010)
Minimum distance from furnace vent to bathroom fan vent? pttcc HVAC 1 08-25-2010 08:54 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
Furnace Vent abfhand HVAC 7 01-14-2008 04:12 PM
