Old 09-06-2012, 09:43 PM   #1
Question
can i use a r410a acoil with a 13 seer r22 condenser.
I have a 3 ton condenser r22 with a r410a a coil by Nordyne model # c7bam03648c-c. The piston in the A coil is .067 The condenser is suppose to be .073. so i picked one up but it doesnt fit. The one in the a coil is way smaller. Can i use the .067 thats in the coil now. Thanks for any help in advance
nooche is offline   Reply With Quote
Old 09-06-2012, 10:07 PM   #2
An old Tradesmen
Won't cool right. Guess you didn't get the piston from a Nordyne distributor. that is where you'll need to get it from, or a friendly Nordyne dealer.
Old 09-06-2012, 10:09 PM   #3
I'm Your Huckleberry
You can always spend just a little more and by an R-22 txv which replaces the piston altogether.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-07-2012, 07:30 AM   #4
Bchill
Txv is definitely the way to go
Affordable Comfort, assisting with
and surrounding area, as well as offering 24 hour
Acomfort is offline   Reply With Quote
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 08:57 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Seer 10 evap coils bad, Go to Seer 13??? pcumming HVAC 5 09-01-2010 06:21 PM
Discuss condenser name plate rates and actual loads. SEER ratings viper HVAC 9 08-27-2010 08:59 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
