Old 08-27-2012, 12:36 PM   #1
Can I use differrent manufacturer for the evaporator coil?
Hi,
I really appreciated if you can help me on this. My house was built on 2004. I got a freon leak and it is really bad and the leak is from evaporator coil. I got two quotes from the AC installer and they are $2700 and $2400 for a new 5 ton carrier evaporator coil replacement. This is way too high for me. I wonder can I use differrent manufacturer coil for a low price.
Here is my system info:
- Carrier 4 ton Condesor with Model: 38EZG048 & Product: 38EZG048300
- Carrier 5 ton evaporator coil with Model: CK3BXA060
I am thinking to replace the evaporator coid with this one:
- Carrier 5 ton Evaporator coil: CNPH6024ACA; CNPH6024ACAABAA
Do you know where I can buy a cheap price for evaporator coil.
tuanngnt is offline   Reply With Quote
Old 08-27-2012, 12:39 PM   #2
Oh by the way, I was quote for a new 5 ton Carrier evaporator coil for $840 (Tax included). This is a quote for part only. For part and labor, the quote are $2400 and $2700. Is this way expensive for part only? For part and labor, I think it is way expensive.
Old 08-27-2012, 04:11 PM   #3
How come I did not see the TXV on my Evaportor coil?
Old 08-27-2012, 04:22 PM   #4
Bchill
you can get away with using a different manufacturer, you just have to make sure the piston is sized correctly. I would recommend going for a coil with a tx valve on it though over piston.
I don't find the coil price too expensive, Carrier parts are generally more expensive.
Affordable Comfort, assisting with
and surrounding area, as well as offering 24 hour
Acomfort is offline   Reply With Quote
Old 08-27-2012, 07:42 PM   #5
An old Tradesmen
Carrier is very very proud of their coils. They come with a big price tag.
Old 08-27-2012, 07:47 PM   #6
Thanks for the replies. I got another quote and I think this quote is reasonable. $1150 for replacing with Payne Evaporator coil (10 years Warranty) or $1500 with Carrier Evaporator Coil (5 years warnt). I think I go with Payne.
The Following User Says Thank You to tuanngnt For This Useful Post:
ben's plumbing (08-27-2012)
Please help to identify basement window manufacturer lb111 Building & Construction 4 12-09-2010 11:19 PM
