Old 01-20-2013, 11:20 AM   #1
can I use a 2 wire thermastat on A/S freedom 80 2 stage furance
if so, which two termenals.... I have twin, w2,w1,R,G,B,Y
bud567 is offline   Reply With Quote
Old 01-20-2013, 11:50 AM   #2
I'm Your Huckleberry
I don't believe you can. r is the 24 volts from the furnace to the stat, G is for operation of the fan, w1 would be first stage heat, w2 second stage heat (which I don't think an 80% gas furnace has), Y is for cooling.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-20-2013, 12:06 PM   #3
If you dont have a/c, you could just hook one wire to R and the other wire to whichever stage you want to use, w2 or w1. You also need to have a thermostat that doesnt need the C wire, just battery only.
sammy37 is offline   Reply With Quote
Old 01-20-2013, 12:07 PM   #4
An old Tradesmen
R and W1. And jumper W1 to W2.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (01-20-2013)
Old 01-20-2013, 12:16 PM   #5
Why the jumper between the two, to run both stages instead of one?
Old 01-20-2013, 12:51 PM   #6
An old Tradesmen
Yep, second stage will come on after 10 minutes that way.
Old 01-20-2013, 03:29 PM   #7
Smile
worked great....thank you
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
How to wire a two stage furnace to fire only on 2nd stage? pirateo HVAC 5 02-01-2010 12:29 PM
