-   -   can I use a 2 wire thermastat on A/S freedom 80 2 stage furance (http://www.diychatroom.com/f17/can-i-use-2-wire-thermastat-s-freedom-80-2-stage-furance-169603/)
bud567 01-20-2013 10:20 AM
if so, which two termenals.... I have twin, w2,w1,R,G,B,Y
Doc Holliday 01-20-2013 10:50 AM
I don't believe you can. r is the 24 volts from the furnace to the stat, G is for operation of the fan, w1 would be first stage heat, w2 second stage heat (which I don't think an 80% gas furnace has), Y is for cooling.
sammy37 01-20-2013 11:06 AM
If you dont have a/c, you could just hook one wire to R and the other wire to whichever stage you want to use, w2 or w1. You also need to have a thermostat that doesnt need the C wire, just battery only.
beenthere 01-20-2013 11:07 AM
R and W1. And jumper W1 to W2.
sammy37 01-20-2013 11:16 AM
Why the jumper between the two, to run both stages instead of one?
beenthere 01-20-2013 11:51 AM
Yep, second stage will come on after 10 minutes that way.
bud567 01-20-2013 02:29 PM
worked great....thank you
