Can I Use A 2-pronged Run Capacitor With This Bryant Air Condensor? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 03:17 PM   #16
JJboy's Avatar
Originally Posted by dmmx3 View Post
what do you mean?
Keep what you did in 2. The Fan is working. You have the blue to H ( cap ) now you need make sure the other 2 wires are connected at contactor.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-28-2011, 03:27 PM   #17
which other two? the purple and black from the fan motor? they are connected to L1 and L2, as shown
I'm sorry if I am misunderstanding what you are asking me to look at.
dmmx3 is offline   Reply With Quote
Old 06-28-2011, 03:41 PM   #18
JJboy's Avatar
Forget about the Fan. It's working. Since the compressor is not working and you already have the blue connected on dual cap ( H ). you need to check 2 more wires coming from the compressor. These 2 wires need to be connected on the same side of the contactor where the fan is connected.
The Following User Says Thank You to JJboy For This Useful Post:
dmmx3 (06-28-2011)
Old 06-28-2011, 03:55 PM   #19
Ok. The contactor is upside down I think. Ls are on the bottom. Ts are on top. 1s are on the right. 2s on the left.
The yellow wire from compressor is on a screwdown connection at top right. The black wire from compressor is on screwdown connection at top left.
The purple fan wire is on spade connectoon bottom right. The black fan motor wire is on spade connection bottom left.
Is this ok?
Old 06-28-2011, 04:12 PM   #20
one other thing i was just thinking about..
the old fan had a black spade connection that landed in the motherboard looking thing at the top. there is a postcard-sized circuit board, and at the top right of that there is a black plastic box with two spade connections. one is still plugged in (a thin black wire), and the other is empty.
is this causing a problem? or is this ok?
Old 06-28-2011, 04:22 PM   #21
JJboy's Avatar
I hope these help.
Old 06-28-2011, 04:37 PM   #22
These do help, and thanks so much for your help and patience.
A couple simple questions:
you show the connections going to the T side? not the L side? does this matter?
Also, does the L1 (for example) apply to the screwdown connection as well as the spade connections on that side? Similarly, is this how it works for L2, T1, T2?
Old 06-28-2011, 04:46 PM   #23
JJboy's Avatar
There are two wires coming in from outside that are connected to one side of the contact. The Another side of the contactor is for fan, compressor connections.
Old 06-28-2011, 04:48 PM   #24
AKA HVACTECHFW
Rewards Points: 1,208
L1 and L2 are the line volt side of the contactor coming from the house. T1 and T2 are load side of the contactor. Regardless of what it says on the contactor L or T.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-28-2011, 05:25 PM   #25
I confirmed that I have this wired per your 2nd diagram. I still am getting no cold air.
The spade connection that is no longer in the circuit board? is that significant?
Old 06-28-2011, 07:00 PM   #26
An old Tradesmen
Rewards Points: 6,588
look at the wiring diagram on the panel, and follow it, and wire the new dual up as it shows.
Replacing a Capacitor in my Bryant Condensor Radhikesh HVAC 1 08-21-2010 11:51 AM
Condensor is not starting, why not? tburk HVAC 15 08-15-2010 12:00 PM
Bryant Condensor kb3ca HVAC 4 06-30-2010 10:23 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
