Can I Run One 5" Pipe Then Split With T To Two? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 08:42 AM   #1
Rewards Points: 201
Can I run one 5" pipe then split with T to two?
In my laundry room, I have 2 break-offs with flexible ducting both going all the way to our bedroom above the garage - one on each end of the room.
In hoping to clean things up a bit, could I run just 1 5" solid pipe to the point where the two flexible ducts go up into the way and simply add a T and run the two from there? That way I only have 1 pipe running down my wall instead of the current 2. There would still be 2 feeds into the bedroom.
What do you HVAC experts think ?
Thank you!
Where one of the pipes goes up into the floor/wall (other is in the floor joist).
Where the pipes break off the main.
NickWa is offline   Reply With Quote
Old 03-16-2012, 09:22 AM   #2
no way you can do that. you'd be adding more resistance to the ducts and cut down the airflow.
hvac5646 is offline   Reply With Quote
Old 03-16-2012, 09:26 AM   #3
Rewards Points: 201
Darn, guess I will have to run them side by side. Oh well, solid pipe will inevitably look better. There's no problem using solid pipe for the first 8' off the main and then continue to the flexible that is currently in place right?
Old 03-16-2012, 10:28 AM   #4
Rewards Points: 380
No problem with running hard pipe and then switching to flex. If you only wanted to run 1 supply and tee off then you could replace one of the 5" take offs with a 7" take off, run 7" hard pipe over to your proposed tee location and reduce to the 2-5" runs from there. You would then blank off the other 5" take off hole in the main trunk duct.
HVACDave is offline   Reply With Quote
Old 03-16-2012, 10:32 AM   #5
Rewards Points: 201
Excellent, thanks a lot for that info!
I will see if local stores at 7" I only ever notice 4" and 5". Would rather 1 x 7" than 2 x 5".
Old 03-16-2012, 01:02 PM   #6
not so sure that will work....your going to run the volume of two five inch flex ducts thru one seven inch flex...unless i am wrong that will not be large enough to carry the same volume as the two five inchers.
Old 03-16-2012, 04:41 PM   #7
An old Tradesmen
Rewards Points: 8,202
How well do those 2-5" supplies keep your bedroom heated and cooled?
Old 03-17-2012, 09:29 AM   #8
Rewards Points: 123
Doing the math:
2.5*2.5*3.14*2=39.25 sq in for two 5 inch pipes.
3.5*3.5*3.14=38.46 sq in for one 7 inch pipe.
Looks to me like HVACDave got it right.
readar is offline   Reply With Quote
Old 03-17-2012, 09:48 AM   #9
An old Tradesmen
Originally Posted by readar View Post
Doing the math:
2-5" pipes move less air then 1-7" pipe.
Old 03-17-2012, 10:26 AM   #10
Yeah, but than it tees off to two fives.
Old 03-17-2012, 10:28 AM   #11
Those look like formulas for hard pipe. This is flex.
Old 03-17-2012, 10:33 AM   #12
An old Tradesmen
2- 5" flex move less air then 1-7" flex.
Old 03-17-2012, 10:36 AM   #13
Didn't answer the question.
That's ok. ..
Old 03-17-2012, 10:37 AM   #14
An old Tradesmen
That's ok. ..
What/which question.
Old 03-17-2012, 10:39 AM   #15
The one I asked..which one did you think I was asking about?
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
How to protect PVC pipe when soldering near it? Studly Plumbing 8 11-21-2011 10:10 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
