Old 10-06-2012, 09:38 PM   #1
Can I run Lineset in PVC?
Ok so I'm getting ready to finish my basement. My AC is current R22. I suspect It'll have to be replaced at some point. I'm thinking about running a empty pvc line to allow for a future new lineset without having to tear up drywall. I need to go up and then left (2 90's). However I only have room for a 2" pvc. Will the lineset take these two bends? I'm also wondering if I should even bother with this. From what I've been reading it's possible to reuse a lineset but most don't seem to recommend it.
nateo is offline   Reply With Quote
Old 10-06-2012, 09:57 PM   #2
An old Tradesmen
Won't be able to run a new line set through it.
Unless your current line set leaks down the road, or is too small for a new R410A system, no reason not to reuse it.
The Following User Says Thank You to beenthere For This Useful Post:
nateo (11-23-2012)
Old 10-07-2012, 08:07 AM   #3
if your line set is the size you will need for your new system later....you can use a flush kit to reuse it with 410 a system.. you won't be able to insert a new line set through 2" with 90s in it.....ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-07-2012), nateo (11-23-2012)
Lineset "Inverted Trap" Question Jim33 HVAC 10 03-26-2012 07:17 PM
Lineset Length RKory HVAC 4 03-17-2012 02:11 PM
Questions on replacing lineset OtherHand HVAC 6 04-26-2011 09:37 AM
Lineset Install Einride HVAC 7 06-26-2009 08:00 PM
90 degree end of lineset?? davidc HVAC 2 05-25-2007 01:46 PM
