Can I Reduce The Vent Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2009, 08:58 AM   #1
Professional Wood Geek
beth n rod's Avatar
Can I reduce the vent size?
Hello,
We are doing home improvement on our own home. We are contractors, but our area of specialty is wood care, not HVAC.
Our upstairs hall has a large vent, when you remove it there is a large space and a small duct down low at the bottom of it. The area is next to the bathroom. We would like to open that wall up and create a recessed cabinet in the bathroom and reduce the vent area, but do not know if this will restrict airflow, or what our limits should be and wanted to check before doing this. Would be glad to take measurements, post pics, whatever....
Please advise....
Beth
beth n rod is offline   Reply With Quote
Old 08-22-2009, 10:47 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 150
Where do you live, how old is the house and post a pic of the grill and vent in it. It may be a return vent from an old gravity furnace and then converted to a new furnace. You should be able to reduce it to the size of the vent it is attached to. I would stay a bit larger so it does not whistle/have air noise on the new smaller grill.
Old 08-22-2009, 11:54 AM   #3
beth n rod's Avatar
Thanks Yuri! I'll take photos this weekend and upload them.
House is 27 years old, we are the second owners. Same heating/cooling type system it has always had, electric house, heat pump. The vent I am talking about is a air reclaim vent (according to my hubby Rod) it just sucks air in. I'll get measurements and photos for you. I'm in Maryland on the east coast.
Beth
Old 08-22-2009, 12:22 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 150
Sounds like it is part of a HRV or ventilation system.
How to Reduce pipe size wrv369 Plumbing 5 05-22-2012 12:33 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 05:07 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
