Can I Place Cold Air Return In Closet? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 05:40 PM   #1
Post
Can I place cold air return in closet?
Can a cold air return be in a closet? I have 2 bedrooms next to furnace room and I don't want to place the return that close to the furnace and was hoping the closets would be ok for the returns.
RAYCC3 is offline   Reply With Quote
Old 09-14-2009, 05:44 PM   #2
An old Tradesmen
Rewards Points: 6,560
No, it is a code violation.
No return allowed in a closet.
Old 09-14-2009, 05:47 PM   #3
Any suggestion on where to put them if not in closets? Can I put them on the wall of the furnace room?
Old 09-14-2009, 05:52 PM   #4
An old Tradesmen
As long as they don't draw air from the furnace room.
Old 09-14-2009, 05:56 PM   #5
Thank you. I will move them for sure. I dont need to be in a code violation and it isn't hard to move them and do it the right way.
Old 09-14-2009, 11:53 PM   #6
Registered User
Termite's Avatar
Help me understand this one guys...
What's to say a return air can't be in a bedroom? I agree it makes no sense to put it in a closet as it certainly won't function well.
Of course the code says you can't access a fuel-burning appliance via a bedroom and you can't pull combustion air from a bedroom, but I'm not seeing a problem with having a return air in there. What am I missing?
Old 09-15-2009, 12:37 AM   #7
An old Tradesmen
Nothing wrong with it in the bedroom.
But not in a closet, nor can the closet be used to convey return air from the bedroom.
Maybe he doesn't want to hear any noise from it.
Old 09-15-2009, 03:19 AM   #8
Post
The reason why I chose my closets for the returns is that 2 walls are exterior walls and the other is the closet wall and the other walls are next to the furnace room.
I have another problem..... the only wall I can put the return on I am on a floor joist.... can I cut or drill holes thru this joist for the return?
Old 09-15-2009, 05:06 AM   #9
An old Tradesmen
Check with your local building code department, if your allowed to or not.
Structural support. Generally not.
But, sometimes you are allowed to notch it.
Old 09-15-2009, 10:45 AM   #10
Thank you!
return air honola HVAC 11 08-13-2009 08:41 AM
cold air return ponch37300 HVAC 9 02-15-2009 10:55 PM
question on return duct familyman HVAC 13 01-25-2009 12:05 PM
Cold air return? swpowe HVAC 13 12-16-2008 04:36 PM
cold air return duffers HVAC 4 01-15-2008 08:37 AM
