-   -   Can I place cold air return in closet? (http://www.diychatroom.com/f17/can-i-place-cold-air-return-closet-53002/)
RAYCC3 09-14-2009 04:40 PM
Can a cold air return be in a closet? I have 2 bedrooms next to furnace room and I don't want to place the return that close to the furnace and was hoping the closets would be ok for the returns.
beenthere 09-14-2009 04:44 PM
No, it is a code violation.
No return allowed in a closet.
RAYCC3 09-14-2009 04:47 PM
Any suggestion on where to put them if not in closets? Can I put them on the wall of the furnace room?
beenthere 09-14-2009 04:52 PM
As long as they don't draw air from the furnace room.
RAYCC3 09-14-2009 04:56 PM
Thank you. I will move them for sure. I dont need to be in a code violation and it isn't hard to move them and do it the right way.
Termite 09-14-2009 10:53 PM
Help me understand this one guys...
What's to say a return air can't be in a bedroom? I agree it makes no sense to put it in a closet as it certainly won't function well.
Of course the code says you can't access a fuel-burning appliance via a bedroom and you can't pull combustion air from a bedroom, but I'm not seeing a problem with having a return air in there. What am I missing?
beenthere 09-14-2009 11:37 PM
Nothing wrong with it in the bedroom.
But not in a closet, nor can the closet be used to convey return air from the bedroom.
Maybe he doesn't want to hear any noise from it.
RAYCC3 09-15-2009 02:19 AM
The reason why I chose my closets for the returns is that 2 walls are exterior walls and the other is the closet wall and the other walls are next to the furnace room.
I have another problem..... the only wall I can put the return on I am on a floor joist.... can I cut or drill holes thru this joist for the return?
beenthere 09-15-2009 04:06 AM
Check with your local building code department, if your allowed to or not.
Structural support. Generally not.
But, sometimes you are allowed to notch it.
RAYCC3 09-15-2009 09:45 AM
Thank you!
