Can I Install An HVAC Unit Myself? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 02-20-2012, 04:27 PM   #16
Yeah I know, its a bit of an exaggeration. Just trying to signify that DIY is not so appealing as to warrant any fear for losing HVAC jobs. If anything affects that it'll be people not being able to afford their mortgages, let alone their HVAC systems.
Ill probably end up just having the guy come out simply because its more complicated than I thought it'd be. I dont want to fool around with $4,000 worth of equipment.
Thanks again for all the responses, you've helped me weigh the options more accurately.
Madix is offline
Old 02-20-2012, 04:40 PM   #17
An old Tradesmen
Rewards Points: 7,356
Please keep us apprised of how your install goes.
beenthere is online now
Old 02-20-2012, 04:42 PM   #18
Originally Posted by Marty S. View Post
There' at least a couple members on here that have done furnas installs themselves. It is possible if you follow the directions exactly and have the correct tools.
what are the correct tools?
Hardway is offline
Old 02-20-2012, 05:04 PM   #19
Too many to mention and they cost about ten grand worth.
hvac5646 is offline
Old 02-20-2012, 05:10 PM   #20
Really, I installed my own HVAC in a new 2400 sq feet structure including all the duct work. The only thing I had to buy was Aviation snips. Oh by the way it was inspected and passed first time out!
Hardway is offline
Old 02-20-2012, 05:19 PM   #21
Rewards Points: 484
He's posting package units and others are talking about welding linesets, confusing thread. If your replacing package units, there will be NO linesets.
So lets assume the OP is replacing package units, much easier job than a split system.
Can you install it yourself? Yes and like beenthere says, skills and tools.
I taught myself 95% of what I know when it comes to havc and I can do some darn nice work. If you have common sense and take enough interest in something, you can learn it. I started collecting air conditioning sales brochures when I was 8 years old and my grandfather taught me almost everything I needed to know in the electrical field when I was very young.
To the OP. Take lots of measurements and find a sheet metal shop to fab up your metal for you, hopefully you can handle the electrical, gas etc.
sammy37 is offline
Old 02-20-2012, 05:27 PM   #22
I almost quit before I even ran the first duct from the main trunk. I had a hell of a time cutting the first hole, then I figured out I had a bad set of aviation snips, took them back and got a replacement set. I can cut and install a collar in ten minutes.
buy flat sheets and use a cleet to bend corner and zip screw it together and tape to seal. the plenum and the return will need to fab.
Hardway is offline
Old 02-20-2012, 05:35 PM   #23
Furnace- A brake and sheet metal hand tools for making the duct transitions along with a lock former, can be all hand bent and S-locked together but looks sloppy. A manometer for getting the gas close, a combustion analyzer to get it dialed in right. The manometer and a thermometer for getting the static and blower cfm set up right.
AC-reclaim machine and tank,torches,nitrogen tank and regulator,silphos rod, copper fittings,vacuum pump,micron gauge, manifold set,clamp on thermocouples for checking superheat and subcool,multi-meter for checking amps and voltages and possibly a tank of refrigerant.
That's the basics.
Marty S. is offline
Old 02-20-2012, 05:50 PM   #24
Really?
What did u use for fasteners? how did you assemble the flue and chimney liner?
What did u use to measure gas pressure?
What did u use to to connect electrical?
What did u use to connect cold air boot?
What did u use to measure chimney draft?
Grain of salt
hvac5646 is offline
Old 02-20-2012, 06:00 PM   #25
Also The way you describe bending the metal would never pass an inspection.
And the question u asked assumed installation of all different types of hvac equipment, not just furnaces. The cost of all the tools and instruments is ten grand for a well equipped tech.
To say you used only a pair of snips is miss leading because than you turn around and say u used zip screws. Makes a good beer drinking story but does not pan out in knowledgeable company.
hvac5646 is offline
Old 02-20-2012, 06:05 PM   #26
gee my post didn't show. Testing one two three.
hrjrkr is offline
Old 02-20-2012, 06:08 PM   #27
An old Tradesmen
The thread was cleaned up, some post were removed.
Old 02-20-2012, 06:19 PM   #28
An old Tradesmen
Post were removed to keep the thread on track. Bickering is not what this thread or site is about. And any thread that seemed to call someone out in an ill or finger pointing manor was removed.
Old 02-20-2012, 06:29 PM   #29
We give our time freely. No place for back biting. And the pros do not deserve what you are selling.
hvac5646 is offline
Old 02-20-2012, 06:34 PM   #30
HVAC Tech/ Browns Fan
Once again I speak my mind and got deleted. Why can I say what I feel!!!
Tator1076 is offline
Closed Thread
Lennox HVAC in Watchguard Mode (4+1) onefastwrex HVAC 19 01-10-2012 04:28 PM
Install water mister by outdoor unit? slickwilliam HVAC 18 07-25-2011 06:43 PM
Rheem hvac unit Lisa Hale HVAC 1 12-19-2010 12:47 PM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 05:24 AM
Need a new hvac unit jjjbh HVAC 5 01-06-2010 08:59 AM
