Can I Heat Beneath My Floor? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 02:26 PM   #1
Can I heat beneath my floor?
We plan to install ceramic or porcelin flooring in our kitchen farmhouse. We are limited by the thickness of the cement board and tile due to the height of the floors of the neighboring rooms and doors. That rules out electric pads sandwiched between the board and the tiles (not to mention the cost of the same).
Could I install pex tubing in the basement under the Kitchen floor and install metal mounting trays to reflect the heat up thru the floor. I have forced air gas heat throughout the home but am considering using the hot water out of my gas water heater. Sounds like a stretch, but it seems feasible in my own mind.
Where can I look for the reflective heat tube trays and hot water pump?
lwendt is offline   Reply With Quote
Old 12-12-2010, 02:57 PM   #2
http://www.radiantec.com/index.php
This site may help.
SKIP4661 is offline   Reply With Quote
The Following User Says Thank You to SKIP4661 For This Useful Post:
lwendt (12-12-2010)
Old 12-12-2010, 03:00 PM   #3
Civil Engineer
Rewards Points: 4,568
If you think that electric floor mats are too expensive, I believe you are going to find that PEX water heat in your circumstance is even higher. First, you don't have a boiler, only a hot water heater, so you are going to need a lot of plumbing to make it work. Even then, your hot water heater may not be able to deliver an adequate amount of hot water to run the floor system and deliver hot water to your house.
If you want to pursue it, check out the Wirsbo (Uponor) web site, they have extensive discussion about methods for installing PEX hot water heat, reflectors etc.
Just a point though, electric mats can be as thin as 1/8 inch, it is hard to visualize why that would create an insurmountable problem in terms of floor elevation.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
lwendt (12-12-2010)
Old 12-13-2010, 07:00 AM   #4
I don't have a very large area to heat. There is a large island in the kitchen and with cabinets, the floor area is not very large.
Hydronic Radiant Floor Heat KGP HVAC 22 05-02-2011 09:31 AM
which comes first..ditra or floor heat? big guy1 Flooring 7 03-30-2010 09:29 AM
Installing pex radiant floor heat, questions. iMisspell HVAC 27 01-15-2009 08:03 PM
No/little heat on 3rd floor apt collar Plumbing 3 12-06-2008 08:17 AM
Baseboard heat clearance above floor xbrickmaker HVAC 4 10-04-2008 02:06 PM
