Can I Do This? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 07:14 PM   #16
Here, I'll post pictures so you guys can get a better idea. I'm awful at describing things.
This is the water heater and furnace/coil sitting in the garage.
This is the other side of the garage. Entry into the aforementioned basement. You can also see the vents that let in air.
This is the finished basement. It's basically a room inside of a room. The GC did all the wooden framing and the drywalls are attached to said framing instead of the house frame. He framed around certain pipes and ducts and also built a little service entry to give access to the areas. Note the low ceilings.
Here's the access entry
It lead's into this..
So once you're in this crawl space type of area, you will see these vents that I've been talking about.
Those vents are what I would 'like to' close off, while getting some kind of dehumidifier in there to keep humidity levels in check. Currently my hygrometer shows 62% RH @ 70 degrees, which I think is a little high.
You guys are probably right. They might have been placed there for a reason, which is what I'm trying to figure out.
My options right now are to either close them off and add a dehumidifier or to leave them and try to seal off every leak into the finished basement to create an air tight seal.
ANGRYKOREAN is offline   Reply With Quote
Old 06-14-2011, 07:29 PM   #17
Rewards Points: 150
Hm, strange little area.
Personally, i'd leave it.
Maybe it has something to do with ventilation similar to what'd you see in an attic like a gable vent.
Removing them would probably cut off all ventilation and make the space even hotter and more humid causing mold growth.
alecmcmahon is offline   Reply With Quote
Old 06-14-2011, 07:49 PM   #18
I should also state that the vents were there before the basement was finished. Before the basement was remodeled into a room, it used to just be dirt and concrete.
Closing them off would definitely cut off ventilation. Now I'm not too sure about this, I'll have to check later, but I think there might be an air duct from our central ac that blows into here as well. I know that when the air turns on, I can hear a strong gust of wind blowing.
I was hoping that I could take care of potential mold/mildew problems with just a dehumidifier. You can see from those pictures that dust and dirt from outside really get into that area. Along with all sorts of insects. The basement is remodeled to be a living quarter so it just feels weird to know on the other side of the walls is filled with so much dust/dirt and bugs.
Old 06-14-2011, 07:56 PM   #19
Rewards Points: 150
I think somebody mentioned it above, why not get one or two of those cheap fiberglass filters and cut it to size and fit it in nice and snug, should prevent crap from getting in, but still ventilate the area if necessary.
as far as having a cold air supply in there, probably un-necessary and lowering the efficiency of your system, maybe cap it off, and then insulate the room, if not fully done already ?
Old 06-14-2011, 08:11 PM   #20
Oh, I had no idea I could just use a fiberglass filter. That sound's like a great solution. If I do go this route, I would not purchase a dehumidifier. So I need to be certain that putting one of these filters to cover the vent will not have any adverse effects. What do you think?
Personally, I don't know the first thing about insulation. I do know that there is hardly any insulation in the room. The grey plastic sheet insulation that you see in some of those pictures is pretty much the only insulation. I have no clue how I would go about insulating the space because some areas are unreachable. The central a/c doesn't blow into the living space so in the future I did want to add a mini split a/c. You're right however, that cold-air supply is probably unnecessary. It doesn't get too hot down there and if there was proper insulation, as you said, would fix whatever minor temperature problem there is. I think having a mini split would however, be a nice little luxury to have.
