#1 |
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils?
I have attempted installation of VP 8000 (prev. used with gas pack) to Heat Pump which existing wall wiring includes wire for aux (heat coils). The VP 8000 does not have 'aux' connection. My preference is not to use the heat coils anyway, as I have other sources of home heating and like the flexibility to lower temp at night by 5 degrees and can wait the extra time for heat pump to raise temp in the AM. However, after installing the V PRO, the heat pump is not coming on when I raise the thermo above existing heat, even tho I can hear the V PRO click and indicate Heat On. I can only assume there is some limitation by the heat pump by not having the white (aux) wire connected at the V Pro. Help please.
#2 |
set option 170 to 2
#3 |
Professional
If you are not going to use back up heat then yes you can use a th8110. But if you want to use backup heat then you need a TH8220 or higher stat. The limitation will be that the HP will only continue heating the home until you reach the thermal balance point of the home vs the outside temp.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by hvactech126; 01-15-2012 at 06:12 PM. |
#4 |
HVAC Tech/ Browns Fan
You have gas as back up heat?
#5 |
7-Day Programmable Thermostat - RTH8500D Honeywell
#6 |
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? Honeywell 7-Day Universal Programmable Touchscreen Thermostat Item #: 300976 | Model #: RTH7600D1022 This is from lowes |
#7 |
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? |
#8 |
I just put that stat in yesterday and its good for 3heat/2cool
#9 |
Professional
Honeywell has 3 different models of the 8000 series stat
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#10 |
Only problem I see is when the unit goes into defrost mode you will be getting cold air with the possibility of your indoor coils freezing.
#11 | |
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils?Quote:
The indoor temp is not low enough, nor does the unit run in defrost long enough for the indoor coil to freeze up. thousands of homes here in the southwest dont even have auxillary heat added to them. |
| The Following User Says Thank You to sammy37 For This Useful Post: | TimDavis (01-17-2012) |
#12 | |
See if setup step 350 is available. If it is and the outside temp. is lower than the lockout set point the compressor wont come on and without axillary heat you wont get any heat. |
#13 |
The 3 models available are the TH8110 (1 heat/1cool),
TH8320 (up to 3 heat/2 cool) and TH8321 (up to 3 heat/2 cool with humidity display and optional overcool to dehumidify) . The shaded areas are only available with the TH8320 and TH8321. Option 350 is only available with the TH8320 and TH8321. (The picture shows this information) If this is a TH8320 or a TH8321 set option 170 to 7. The OP posted that this is a 1 heat/1 cool stat in the original post. |
| Display Modes | |
| Heat Pump Crisis Part II | Doc Holliday | HVAC | 58 | 12-07-2011 10:14 PM |
| Which honeywell thermostat should I buy for my Carrier heat pump? | mannypp | HVAC | 29 | 01-30-2010 03:21 PM |
| Heat Pump Blower always on | gg_daman | HVAC | 1 | 12-16-2009 07:15 AM |
| Fujitsu Heat Pump Concerns | SanDiegoCool | HVAC | 3 | 03-19-2009 01:27 PM |
| Wiring help - Honeywell Thermostat w/ Carrier Heat Pump | Tom Williams | HVAC | 7 | 09-14-2008 08:40 AM |
