Can A Furnace Sit On Top Of The Evaporator Coil? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 11:43 AM   #1
Can a furnace sit on top of the evaporator coil?
Hi, just bought my first home (cute little ranch) built on a slab, so there is no basement or crawl space. we have a utility closet off of the kitchen that houses the water heater, furnace and evaporator coil. (I know, if it's not broke don't fix it, but just want peace of mind to know that is is set up the way it should be) I see a lot of info on line about the coil sitting on top of the furnace but our furnace sits on top of the evaporator coil. All is seems to be working fine, but then again, I have never had a place with central air so I have a lot to learn. Any in put is greatly appreciated.
Sincerely, Yvonne
Yvonnef11 is offline   Reply With Quote
Old 03-13-2012, 11:48 AM   #2
Rewards Points: 268
Not a problem. It takes air in the top and flows it down past the burner and A coil, into the duct work.
JackDidley is offline   Reply With Quote
The Following User Says Thank You to JackDidley For This Useful Post:
Yvonnef11 (03-13-2012)
Old 03-13-2012, 11:58 AM   #3
furnace on top of AC Coil
Thank you so much for your reply.
Old 03-13-2012, 01:06 PM   #4
An old Tradesmen
Rewards Points: 6,124
Yep, its normal if your duct system is in your slab.
Old 03-13-2012, 02:30 PM   #5
normal if on a slab
Oh..... you know that is a good question, I have no idea if our duct work is in the slab. I will have to try and find out.
thank you for your reply.
Old 03-13-2012, 02:39 PM   #6
An old Tradesmen
Are your registers on the floor, or in the ceiling.
Old 03-13-2012, 11:54 PM   #7
REP
The one thing that can hurt a htg. and a/c system is a dirty filter.Make sure you know where your filter is and how to change it and change it every few months.
REP is offline   Reply With Quote
Old 03-14-2012, 07:29 AM   #8
furnace sitting on top of evap coil
Hi,
The registers are on the wall about 8 inches from the floor. A friend came over last night and showed me where the filter is located and how to change it. Turns out they had a "cheapie" filer in it so had to get a good proper filter.
Old 03-14-2012, 04:14 PM   #9
An old Tradesmen
Probably comes up through the slab into the wall. Don't get "too" good of an air filter. as most duct systems weren't designed to use them.
Old 03-15-2012, 07:24 AM   #10
air filter
thanks, I'll look for a "Middle of the road" pleatted one.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
