Old 02-05-2008, 07:01 PM   #1
Can a fireplace heat through my central unit?
I have a fireplace insert that utilizes a metal flue pipe. Is there a way to harness the heat from the flue pipe and duct it into my central heating unit?
Randell Tarin is offline   Reply With Quote
Old 02-05-2008, 07:12 PM   #2
Eibwen
I have seen some double walled inserts that can be vented into ductwork. Mine has a blower on it so there really is no need to for the floor plan we have.
But if you have just a flue pipe to work from, it would take a lot to reclaim any heat into the ducts.
A blower on the insert and some ceiling fans to circulate would help.
Sammy is offline   Reply With Quote
Old 02-05-2008, 07:30 PM   #3
I have a blower on mine, but it's set into a room with a vaulted ceiling. We have a ceiling fan set to blow the warmer air at the top of the room and that seems to work quite well. The problem is only the great room and kitchen are heated by the fireplace.
Old 02-05-2008, 08:36 PM   #4
Eibwen
If you have a heating system with an air return near the fireplace, you may try running just the fan on recircualte or on without the heat. That would help distribute the heat throughout the house.
Old 02-13-2008, 04:48 PM   #5
alot of replies but...no one is addressing the draft issue....if you lower your flue temp. to much you lose your draft, causing a smokie fire and worse, carbon monoxide in the home.
econoline is offline   Reply With Quote
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 08:31 AM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
Need to remove old central air unit pmb003 HVAC 4 05-03-2006 05:05 PM
