Can A Compressor Be Patched? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 03:52 PM   #1
Home handyman
Can a compressor be patched?
I replaced a fan motor and the rod was too long and sat atop the compessor which grindedand made a pin sized whole. Fixed the length on the rod to the fan motor but now have a hole in the compressor! Question is, can the hole possibly be patched like with jbwelding or similar? I know it may sound janky but im just trying to find an alternative to spending big $$$ that dont have. Thanks for any advise.
Colion is offline   Reply With Quote
Old 04-16-2012, 04:10 PM   #2
Ravenworks's Avatar
You may be able to find a competent welder to do it,however you will lose your UL listing
I stand corrected,I though you were talking about an Air compressor.
A/C comp= No Fix
Ravenworks is offline   Reply With Quote
Old 04-16-2012, 04:15 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Expensive mistake, the only way to really learn!
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
gregzoll (04-16-2012)
Old 04-16-2012, 04:45 PM   #4
An old Tradesmen
Rewards Points: 7,356
Afraid that compressor is done for. The welded seams of refrigeration compressors, are lap seams. It prevents splatter from getting into the compressor. Welding a hole would leave splatter. Using a cover plate would prevent splatter. Of course, you would need a certified pressure vessel welder to do it, and they usually aren't cheap.
Then after all that expense, you would still need the system vacuumed, and recharged. Since r22 isn't cheap anymore, this could be a few hundred bucks more.
And after all that, you have to cross your fingers the compressor last more then a month or 2.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-17-2012)
Old 04-16-2012, 05:05 PM   #5
Experienced
Jackofall1's Avatar
Beenthere couldn't be more correct, you will go through all the trials and tribulations to get it welded and vacuumed and recharged and all the while you will be crossing your fingers.
Chaulk it up to an expensive lesson, see if your Home owners insurance can cover it somehow, not likely but it might be worth a shot.
Mark
Old 04-16-2012, 07:52 PM   #6
REP
Almost anything is possible.
Would it be practical?? No.
REP is offline   Reply With Quote
Old 04-16-2012, 08:27 PM   #7
Rewards Points: 616
I concure
carmon is offline   Reply With Quote
Old 04-16-2012, 08:30 PM   #8
Originally Posted by carmon View Post
I concure
You can cure what, the compressor? (he he)
Thanks.
Old 04-16-2012, 09:01 PM   #9
Rewards Points: 616
you on my case doc.... relax.....lol
Old 04-17-2012, 12:43 AM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Not to mention the oil inside that compressor might not take kindly to sparks
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-17-2012, 08:47 AM   #11
biggles's Avatar
wire wheel 1" around the pin hole flux it up and torbo torch it your hole is on the suction side of the compressor or go spend your tax refund on it...
Old 04-17-2012, 08:49 AM   #12
used to silver braze small holes in comps. would not be afraid to do it now.
hvac5646 is offline   Reply With Quote
Old 04-17-2012, 12:12 PM   #13
Home handyman
Yup I figured. Im outta there on this one.lol. Just goin to opt for a swamp cooler this year n replace that baby next income season. Thanks for all the replies. & yeah I screwd up on this one,joke is on me.haha
Old 04-17-2012, 12:25 PM   #14
Keep your eyes and ears open, you may come across a good used one. God know's how many good one's I've just scrapped out. Heck, I left a brand new compressor, the coil was stolen from the brand new condenser, in the back yard of the home.
Just know the tonnage you need and the make of the compressor for piping reasons. Like for like is the best way.
If you were in my area I'd have no problem hooking you up with one.
Thanks.
Old 04-17-2012, 03:36 PM   #15
An old Tradesmen
Everybody screws up once in a while. Lessons learned are usually worth their cost.
Technow (04-17-2012)
flat patch spots davidhmd Painting 10 11-13-2011 08:32 AM
Patched Drywall is thinner than Original. I need Suggestions. thehip Drywall & Plaster 9 08-02-2010 11:34 AM
