Can Closing Too Many Vents Cause Problems?? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 02:28 AM   #1
Question
Can closing too many vents cause problems??
Newbie here hoping to mine some info. Can closing to many heating vents (to save $ basicly) cause a furnace to lockout due to things like back pressure, overheating, excess condensate or whatever? I had closed 4 of 10 vents and, after several cold weeks, the furnace quit working after a few cycles or sometimes altogether. (In my case, this is a 19 yr old high efficiency furnace) I reopened all vents and room doors and the furnace seems to work again as it should. Just coincidence??? Thanks, Michael
mikeyjjohn55 is offline   Reply With Quote
Old 12-27-2009, 05:21 AM   #2
An old Tradesmen
Rewards Points: 6,598
Closing too many vents can cause the furnace to over heat.
Also. Check your air filter, may be time to replace it already.
Old 12-27-2009, 07:36 AM   #3
Remodeling Contractor
By closing too many vents you are placing the furnace in an out of balance condition. It will overheat.
Old 12-27-2009, 09:26 AM   #4
HVAC Tech/ Browns Fan
If you want to close vent. Just put fan motor on high speed ( red is for heat and its on low speed) Note if you do put it on high speed it may run longer.
Tator1076 is offline   Reply With Quote
Closing Crawlspace Vents -- temporarily Steve Burke General DIY Discussions 7 12-09-2009 08:03 AM
Closing Vents to unused rooms rguerra HVAC 0 07-04-2009 11:19 PM
Closing room vents radtek HVAC 8 05-15-2009 06:16 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 02:39 PM
