-   -   Can closing too many vents cause problems?? (http://www.diychatroom.com/f17/can-closing-too-many-vents-cause-problems-60367/)
mikeyjjohn55 12-27-2009 01:28 AM
Newbie here hoping to mine some info. Can closing to many heating vents (to save $ basicly) cause a furnace to lockout due to things like back pressure, overheating, excess condensate or whatever? I had closed 4 of 10 vents and, after several cold weeks, the furnace quit working after a few cycles or sometimes altogether. (In my case, this is a 19 yr old high efficiency furnace) I reopened all vents and room doors and the furnace seems to work again as it should. Just coincidence??? Thanks, Michael
beenthere 12-27-2009 04:21 AM
Closing too many vents can cause the furnace to over heat.
Also. Check your air filter, may be time to replace it already.
Bob Mariani 12-27-2009 06:36 AM
By closing too many vents you are placing the furnace in an out of balance condition. It will overheat.
Tator1076 12-27-2009 08:26 AM
If you want to close vent. Just put fan motor on high speed ( red is for heat and its on low speed) Note if you do put it on high speed it may run longer.
