Can A Bathroom Fan Vent Under Decking? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 04:33 AM   #1
Can a bathroom fan vent under decking?
Although it may be a moot point (since it appears to be my only option) - are there any problems with venting a bathroom fan out under a deck? It's a basement guest bathroom which will be seldom used. The house is in western NC and the basement is about 3/4 under ground. The bathroom is essentially completely underground save about 18 inches from the bottom of the first floor (porch) decking to the ground.
upinsmoke is offline   Reply With Quote
Old 04-25-2010, 04:51 AM   #2
An old Tradesmen
Rewards Points: 8,154
Not sure.
Guess it depends on what you like to smell while using your deck.
Old 04-25-2010, 10:56 AM   #3
Registered User
Rewards Points: 526
Not a HVAC guy, but i believe it needs to be 3' from any window or door, 4" off the ground, and 10' ? from any fresh air inlet supply.
Perhaps a code expert like K.C. will answer.....
Be safe, Gary
Old 04-25-2010, 11:20 AM   #4
How far away can you smell a clothes dryer output? This is probably a safe distance for a bathroom, depending on the diet of the users.
Old 04-25-2010, 12:04 PM   #5
An old Tradesmen
LOL...
Guess that depends on how sensitive a person is to different odors.
I can see having an outing. And half the people can't smell anything from it. And the other half going to the other end of the yard to get away from the odor.
Old 04-25-2010, 12:43 PM   #6
sktn77a's Avatar
Rewards Points: 392
Can you run the vent to the edge of the deck so that it doesn't vent up into the decking? It may mold in the summer and freeze in the winter if it just vents straight out of the house. Also it can allow damp to get under the ledger flashing and rot the deck/side of the house. Not good!
sktn77a is offline   Reply With Quote
Old 04-25-2010, 12:53 PM   #7
I'd never do it myself
Very embarrasing to have someone use the bathroom & then come out to the deck to see everyone holding their nose
Old 04-25-2010, 02:53 PM   #8
Are bathroom odors:
1. heavier than air
2. lighter than air
3. neutrally buoyant
Old 04-25-2010, 04:59 PM   #9
Man-o-man you guys are so funny. The thought of the "user" coming out onto the deck and everyone has clothes pins on their noses just slayed me
Now, on to the business at hand (arh!). Unfortunately, I believe that I'm stuck with the location stated and running it across the width of the deck would only move the problem from one side of the deck to the other.
I was mainly looking to see if there was a code issue - but apparently there isn't one as long as I'm close to the parameters stated.
If the odor turns out to be a problem - I'll buy a half a dozen of those little scented pine trees. It's a cabin in the woods so it'll blend right in
Rick
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Bathroom Fan Vent gruntman Roofing/Siding 10 03-10-2010 08:16 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Bathroom vent directly over a rafter Kirgan Roofing/Siding 6 03-11-2009 01:30 AM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
