Can Any1 Help Find A Pressure Switch? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 02:50 PM   #1
can any1 help find a pressure switch?
ok this is my promblem.. I have a carrier furnace model# 58RAV095-12 and some one before me put a universal pressure switch on the furnace but everytime i turn it on it bliks code 31. Tested pressure switch its good but i dont think that they setted the switch correctly. So i have to find out what the factory setting is on the pressure switch. Does anybody know or if you know what one goes in there that would be great to..
hvac kid is offline   Reply With Quote
Old 12-17-2010, 11:19 PM   #2
Carrier furnace pressure switch settings
I'm sitting here with two generic adjustable pressure sensors, because the Carrier parts stoe couldn't provide me w/ the Carrier pressure switch assembly (not stocked). So, now I have to figure out what the two pressure sensors should be set at. My furnace is a 58SXB; it's a 2 stage electronic condensing furnace . . . am told it's about 20 years old now. I've already put in a new replacement controls module (about $500) and a new gas valve last night (another $200 . . . on recommendations from a qualified person, by phone only), so now it's on to the pressure switches, which my 40 page diagnostic work sheet says is the problem. I've got the new generic switches sitting here, just need to know the settings for low and high switches. Sorta cold in Seattle, with holiday guests coming tomorrow.
ronquist is offline   Reply With Quote
Old 12-18-2010, 02:10 AM   #3
the press setting are printed on the. old ones. post the old numbers and someone will tell you what rating they.
hvaclover is offline   Reply With Quote
Old 12-18-2010, 03:25 AM   #4
An old Tradesmen
Rewards Points: 8,234
Would have been cheaper to call a guy out. Then to have "free" diagnostics done over the phone.
Just as good of a chance that its a bad heat exchanger causing the old pressure switches to do there job.
Old 12-18-2010, 04:10 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
A carrier distributor will be able to tell you their make and break specs. Adjustable p/s are really just a temp fix until the correct ones are available
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-18-2010, 05:56 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 396
Heat exchanger may be full of pinholes causing it to lose draft and trip the pressure switches. Not uncommon with a furnace that age. Had a poster on my previous site that had nothing but intermittent press switch problems. Got to the point where we had him yank the heat ex and tip it on it side and fill it with water. Leaked like a sieve.
Old 12-18-2010, 08:46 AM   #7
Agree with beenthere and yuri.
SKIP4661 is offline   Reply With Quote
Pressure switch or other? rickr01 HVAC 1 11-08-2010 05:28 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Furnace Pressure Switch bigmatt HVAC 10 09-03-2009 06:25 PM
Pressure switch ratings gp_wa Electrical 6 08-31-2009 09:43 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
