Came Home To Cold House - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 07:14 AM   #1
Came home to cold house
Left last night everything was fine...came home this morning and house was cold...checked thermostat and realized filter may be clogged...I'm terrible at maintaining this.... Sure enough ...took out filter but didnt have a replacement....now furnace is kicking on and off every few minutes.. Does it NEED a filter to work properly or is it something else...
Gas furnace, Ruud, about six years old.
Thank you.
dublya is offline   Reply With Quote
Old 11-01-2012, 07:59 AM   #2
Rewards Points: 616
it does not require a filter to work..... but you should definately have one in when its runing.....
carmon is offline   Reply With Quote
Old 11-01-2012, 10:53 AM   #3
how
Rewards Points: 1,104
Does it have a flashing led diagnostic code?
how is offline   Reply With Quote
Old 11-01-2012, 12:17 PM   #4
Rewards Points: 6,652
First thing I would ask is, do you have power going to the house, do you have gas, propane or oil to fire the heat, or is it electric heat.
Old 11-02-2012, 09:57 AM   #5
Rewards Points: 446
Your description of it's kicking on and off doesn't give much to go on. Do you mean the burner(s) are going on and off or do you mean the fan is going on and off? You also didn't mention if while it's going on and off, does the house come up to temperature.
old_squid is offline   Reply With Quote
Old 11-03-2012, 07:15 AM   #6
well both fan and burner would kick on and off...it would only run for a couple minutes....but its working now....I left it off all night so about 8 hours....tried it in the morning and now its working.... thanks
Tags
filter
Replacing home made whole house fan blower rebar HVAC 5 06-23-2009 06:39 AM
Came home to a hot house! Condensor fan not coming on... austinringding HVAC 12 10-19-2008 08:07 AM
new ( to me ) house... cold inside, warm outside... what's the deal? MrLinux General DIY Discussions 7 02-13-2008 08:33 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
