Calculating Cfm - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 10:35 AM   #1
Rewards Points: 24
calculating cfm
My partially finished basement is freezing in winter. No problem cooling in summer. 470sf x 8' ceiling = 3760 cu ft. Currently served by one 6" round supply and one 8" round return. What do I add to make it comfortable?
rufuscobb is offline   Reply With Quote
Old 02-02-2014, 11:43 AM   #2
An old Tradesmen
Rewards Points: 6,958
Electric baseboard.
While you can add 2 more 6 inch supplies and increase that 8 inch return to a 10 inch. The cold air from the first floor will fall down to the basement and keep it cool/cold feeling.
The basement should be on its own trunk line, and the system should be zoned.
Old 02-02-2014, 12:40 PM   #3
Rewards Points: 24
bennthere - good idea that I hadn't considered. Thanks! Curious...why baseboard rather than a wall heater? Maybe something like this? http://www.homedepot.com/p/Cadet-Com...6?N=5yc1vZc4k3
Old 02-02-2014, 12:48 PM   #4
An old Tradesmen
Wall heaters often become loud after a few years. other then that, nothing wrong with using one.
Calculating Overcurrent Protection on the Primary Side. Carandorandy Electrical 1 02-25-2011 11:37 AM
Calculating 90 degree conduit bend Richo Electrical 7 02-01-2011 11:01 PM
??? about calculating loads for a sub panel TKO204 Electrical 4 12-03-2009 07:58 PM
first dry stack retaining wall - calculating tonnage needed? wombosi Landscaping & Lawn Care 1 04-30-2009 07:37 PM
Calculating box size requirements dc4nomore Electrical 12 12-12-2008 07:41 AM
