Cadthdral Ceiling -cold Room - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 12:47 AM   #1
cadthdral ceiling -cold room
Hello,
My husband and I bought this house 2 months ago- and winter is kicking in, we have cathedral ceiling our living room is so cold, do any one have any suggestions, we have a fire place- but it is still cold. need help
jeep2000 is offline   Reply With Quote
Old 02-22-2008, 02:16 AM   #2
You need to give people alot more info than that. Where are you located? How old is the house? Just built? Did you get it inspected before you bought it? How is the house heated, how old is your heating system. how many vents or returns do you have in the room or radiators. What are the levels of insulation in the home? Attic, walls, cathedral ceiling? Is the room over a concrete slab or an unheated basement. How many exterior walls does it have. Is the room super far from the heating system? etc etc.
jaw22 is offline   Reply With Quote
Old 02-22-2008, 07:45 AM   #3
biggles's Avatar
it is typical for high ceilings to pull on the heat being sent into a living room add a couple of big windows and it seems there is no heating going on.more info will give us an idea on what to suggest,does that fireplace have room around the back of it to add a fan option if it is a newer house.the way that would work you have a fire going and fans within the back would pull air across the metal encasement of the burning section to send the heat into the living room.the only thing that controls the heat is the fan on/off and or the size of the fire going.if your ceiling was a typical 8' one you would probably have decent heating within that space.biggest question are you running forced hot air(#vents) or hot water baseboard(footage installed)around the room
Old 02-22-2008, 12:17 PM   #4
I'd be willing to bed that the temperature at the top of your room is 80 degrees. You need a ceiling fan. Run it on slow reverse in the winter. Probably solve all your problems.
NateHanson is offline   Reply With Quote
Old 02-23-2008, 12:35 AM   #5
Thank you everyone, our house was built in 1949, a single family home, in Maryland, and we have one vent in living room, draftier living room window, my husband Will have to repair the windows this summer....... i will talk to my husband about the ceiling fan/////and more suggestion i'm eager to listen and learn.
Old 02-23-2008, 08:56 AM   #6
biggles's Avatar
if you have a big bow window in that room a thermal curtain say Bailie style vertical blinds....especially if the sun heat hits the windows during the day it will get trapped within the glass and the blind to keep it warm.that would be one less load on the i register room.keep in miind heat rises so with the heat running and it cold outside some night get up on a 6' ladder in the middle of the living room an feel if there is heat building up in the hi ends of the ceiling.
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Cold room above garage, Asbestos? Crackers Building & Construction 1 09-09-2007 10:35 AM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
