A/C Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 09:19 PM   #1
A/C won't turn on
Hello All,
New to the site and looking for some info before I drop some big dollars.
We have a heat pump and just recently the A/C quit working. When the A/C is turned on it tries to start (you can see the lights dimming with the electric load) but will not turn on. The outside fan is not turning on. The fan works when set to heat, so i assume that the fan motor is just fine. I wonder if it is low on freon. Mabye a leak or something.
I am an HVAC newbie. Just know what I have read on the internet.
Thanks for all replies.
Eric
luceze is offline   Reply With Quote
Old 11-23-2010, 11:11 PM   #2
New information
Heat does not turn on either now. The outside fan is not starting up but with a little prod starts spinning nicely. Maybe it is as bad fan motor or capacitor?
Any thoughts?
Old 11-24-2010, 05:53 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Sounds like a capacitor....
hvactech126 is offline   Reply With Quote
Old 11-24-2010, 10:08 PM   #4
Run cap as the A/C guy calls it. Did it myself no big deal.
Old 11-25-2010, 11:15 AM   #5
Sounds exactly like a bad capacitor at your outdoor unit. Disconnect power to the unit and remove the cover to the electrical compartment. A capacitor is a little round or oval shaped, silver colored component with wires coming off of 2 or 3 terminal on the top.
Yours probably has three terminals. Write down EXACTLY where each wire goes. The terminals are probably labeled HERM C FAN. If your fan starts when you spin it, but your compressor doesn't start at all you have a bad dual capacitor.
brandonmcginnis is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 04:06 PM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 02:49 PM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
