A/C Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 03:27 PM   #1
Rewards Points: 16
A/C won't turn on
We just purchased a new home and haven't fully moved in yet, but we were doing some work in the house this weekend and tried to run the A/C but it wouldn't turn on. Neither the main unit outside or the blower fan in the furnace would kick on. It worked at inspection and the former owners had it running after that while they were cleaning the house up.
I recycled every breaker in the panel (in case the former owner told me the wrong one for the A/C), replaced the fuses in the disconnect box, all wiring in the service panel looks OK, furnace emergency switch is on, tried the fan switch on AUTO and ON.
The former owners had power turned off the day we closed and we waited a week to reconnect it since we knew we wouldn't be there right away. Would the reconnect have caused a problem? The main breaker for the house was off when it was reconnected and I turned it back on after the power company came out.
Gas is also disconnected at the moment for the same reason. Does the furnace need gas for the A/C to run? Or is it time to call a pro?
dublozrow is offline   Reply With Quote
Old 04-30-2012, 03:32 PM   #2
Rewards Points: 616
furnace does not need gas for a/c to run. is there maybe a service switch somewhere for the furnace turned off....
carmon is offline   Reply With Quote
Old 04-30-2012, 04:01 PM   #3
An old Tradesmen
Rewards Points: 7,288
Make sure blower door panel is on correctly. it has a safety switch in it that could be causing your problem.
Old 04-30-2012, 04:17 PM   #4
biggles's Avatar
is your name on the elecrtic bill former might of taped off the R wire check the disconnect out side up..work on getting that fan to do ON off the stat for now....that will proof 24Vand 115V to the furnace....at least...
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
frost free faucet - cannot turn on terrealta Plumbing 9 04-03-2011 06:18 PM
blower won't turn on in AUTO nhpick02 HVAC 26 12-05-2008 07:27 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
