"C" Wire Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 04-12-2009, 09:21 PM   #1
"C" wire installation
I have a GMP100-4 furnace unit and just got a thermostat to replace a very old inefficient one. The problem is that the new thermostat requires a "C" wire connection, apparently to power the unit (no battery option). Is there a simple fix for this? Can include pics of furnace board if it would help.
tomblack_1 is offline   Reply With Quote
Old 04-12-2009, 09:28 PM   #2
HVAC / Plumbing
The r wire is always hot.
kenmac is offline   Reply With Quote
Old 04-12-2009, 10:16 PM   #3
An old Tradesmen
Rewards Points: 6,900
R=power +
C=power -
Depending which series board you have.
You'll need to wire directly to the transformer common.
Old 04-12-2009, 10:21 PM   #4
HVAC / Plumbing
deleted
Old 04-12-2009, 10:41 PM   #5
An old Tradesmen
The C teminal of the stat connects to the C terminal of the board, or transformer.
Its the same as an A/C condenser needing to be connected to the C terminal of the board or transformer.
You may be thinking of jumping the RC and RH terminals together.
Old 04-12-2009, 10:45 PM   #6
HVAC / Plumbing
been , You got it.. Just looked at mine.. That's exactly what I was thinking.. I deleted the other so he wouldn't get confused.... Thanks been
Old 04-13-2009, 01:15 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,838
If it needs a C wire then another wire would have to be run to the tstat from the furnace ( a huge pain). I would return the tstat and buy a Honeywell Vision or FocusPro as they are battery operated and very good. I saw a very slim Robertshaw type w/o battery and after a power shutdown it was very slow/weird on startup. Did not impress me.
Old 04-13-2009, 01:48 PM   #8
Rewards Points: 12
There is a priduct called "Add a wire" which can "make" an extra wire for you. Probably difficult for a DIY.
KeepItSimple is offline   Reply With Quote
Old 04-13-2009, 02:04 PM   #9
Hvac Pro
yuri's Avatar
Based on my experience those are ABSOLUTELY horrible/unreliable and I hate them. When they go haywire/on the fritz they can damage a circuit board etc. Stay away from them if at all possible or you may be sorry.
Old 04-13-2009, 05:00 PM   #10
More Info...
I have actually run a wire from the furnace to the thermostat, but simply don't know where to connect to the furnace board. Thermostat that my wife purchased has a remote (she wants that). Are there any battery powered models that don't require the C hook up? Thanks for all of the responses. Again, I can provide a pic of the board if that would help.
Old 04-13-2009, 05:34 PM   #11
Hey Yuri, you mean the "Priduct"? Yeah I hate that too when they fail.
Which Priduct do you hate more the Honycomb brand or the Black Dodgers
brand
hvaclover is offline   Reply With Quote
Old 04-13-2009, 05:38 PM   #12
Hvac Pro
yuri's Avatar
You can provide a pic. Some of the Goodmans I ran into don't have a C terminal. You have to trace the leads from the 24v transformer and use wire connectors. The 2 Honeywells I recommended are the best I know of and available at HDepot. I recommend the Honeywell as I am a tech and have seen lots of poor quality thermostats do weird things and can sometimes damage a circuit board. Those 2 require no C wire/terminal.
Old 04-13-2009, 05:39 PM   #13
An old Tradesmen
It has a remote control?
Or a remote sensor?
Old 04-13-2009, 05:40 PM   #14
Hvac Pro
yuri's Avatar
Clover, We have had terrible results with fastst*ts. Had one turn a A/C contactor into a machine gun.
Old 04-13-2009, 06:08 PM   #15
LOL...what caliber was it firing?
Chattering like an SOB I bet. Never tried the product, din't need it or trust it.
I have yet to not be able to get cable to a furnace, and i consider myself quit fortunate for it.
Honeywell has their IAQ stat and there are several wireless product on the market.
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
How difficult is 8 AWG wire to work with? PirateKatz Electrical 13 02-16-2009 12:05 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
